Question about Whirlpool WRS342FIAB 22 cu. ft. Side by Side Refrigerator with 2 Slide-Out SpillGuard Glass Shelves, 3 Adjustable Gallon Door Bins, PUR Water Filtration System, External Water Dispenser and In-Door-Ice Dispensing System: Black
Ice maker red light is blinking
The ice maker on my whirlpool wrs342fiab 22 cu. ft. side by side refrigerator is blinking
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
SOURCE: Problems with Whirlpool 25.6 cu.
Use a screw driver to pry up at the two notches at the bottom of the panel. I thought that might work, but had been afraid if I did I would break the panel.
Posted on Dec 04, 2008
mastatech
  • 478 Answers
SOURCE: freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Posted on Mar 14, 2009
  • 378 Answers
SOURCE: Compresor will not kick on. all fans running,
Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps  ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example oneexample twoexample three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed.
Posted on Apr 03, 2009
sams_trix
  • 93 Answers
SOURCE: My Whirlpool Gold 22 cu.ft. refrigerator stopped
prior to the replacement of the cartridge, the ice maker is okay? if yes , try to re check the installation, there might be something to remove before installation,you can check it also by comparing to the old one, sometimes taking pictures before removing parts can help a lot.
Posted on Aug 27, 2009
Ice maker not working
Ice makers have a heating element to thaw the inlet and allow water to flow into them perhaps the heater is broken and it can't get water to make ice. Check the hopper to be sure it has ice in it. If it does check it for obstructions from the hopper to the door.
Apr 04, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you flush water thru the water filter of my refrigerator
ice maker does not come out water to water hose and ice maker on/off switch red light two times blinking how can i repair to ice maker?
Jan 21, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
WHAT DOES IT MEAN FOR TWO BLINKS N INFRA RED ICE MAKER
Means that the laser eye is not making contact with the other side. Push in the plastic flapper and see if the light goes out. If not replace the laser eyes. If it is making ice it is probably working fine. It ususlly blinks when you open the door.
Jan 31, 2011 | Whirlpool GC3SHEXNQ 23 Cu. Ft....
My Whirlpool Gold 22 cu.ft. refrigerator stopped making ice. I recently changed the water filtration cartridge...could this be related? Any ideas on how I can fix this myself?
Aug 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Seee note on ice maker stopped working, blinking red light
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
rtwywy
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool WRS342FIAB 22 cu. ft. Side by Side Refrigerator with 2 Slide-Out SpillGuard Glass Shelves, 3 Adjustable Gallon Door Bins, PUR Water Filtration System, External Water Dispenser and In-Door-Ice Dispensing System: Black Logo
444 people viewed this question
Top Whirlpool Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Whirlpool Water Dispensing and Filtration Expert? Answer questions, earn points and help others
