Question about Poulan Pe550 Gas Edger
Where to get replacement fuel line for edger
I need to replace rotted fuel lines. Where can I get these fuel lines?
    Master:
  • 706 Answers
Your local hardware store and ebay has a great supply as well.
Posted on Sep 03, 2014
3 Suggested Answers
  • 53 Answers
SOURCE: replacing fuel tank on craftsman edger and other
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Posted on Jul 20, 2009
moretons
  • 155 Answers
SOURCE: The fuel lines have rotted out of the edger gas
no you can buy replacement fuel line but you must reconnect the filter in the tank that line goes to the bottom of the carby then out the top of the carby to the inlet on the primer then out of the primer and back to the tank.
Posted on Jul 25, 2009
The fuel line on my Craftsman trimmer rotted away. How do I fish out the rest out of the tank to replace it?
You may need to take the fuel tank off and fish the old lines out with a pair of needle nose pliers And then check out my Tip on this matter:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Good Luck!
Jim
Aug 11, 2011 | Craftsman Garden
Model no.358791072 fuel lines were rotted.I need a diagram of the proper order
Hi and welcome to FixYa, I am Kelly.
The fuel line WITHOUT a strainer will go from the tank to the OUTSIDE primber bulb connection then from the primer bulb center connection to the carb. Item 7 this link comes with the diagrams:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791072/0247/1503820/P0808034/00002?blt=06&prst=0&shdMod=358791072
There are several you tube videos here on replacing fuel lines:
Something to note... inside the tank there is a fuel filter/strainer. Make sure to replace that fuel line also. The connection from the strainer will connect straight to the carb fuel mainfold connection. The center connection of the primer bulb will go straight to the carb fuel manifold.
http://www.fixya.com/uploads/images/1CE2BC8.gif (Expand to 200%)
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Craftsman 25cc Gas Line Trimmer
Fuel lines rotted. Replaced but cannot prime. Primer pushes back into tank causing fuel to leak at cap vent. Would like to obtain parts manual
i recently worked on a chainsaw that i was putting back together and got the primer bulb lines crossed, it was backwards to the way it should have been, i recommend that you reverse the lines, it is an easy mistake to make when it can be counter intuitive like it was in my case
Jun 28, 2011 | Craftsman 25cc Gas Line Trimmer
Rotted fuel lines
normally one fuel line has a small filter on the end of it. that one needs to be exactly the same size. that one sucks up the gas and sends it to the engine. the other fuel line is for the excess gas / air to return to the gas tank and keeps it from spilling all over you / or wasting fuel. it can be shorter but is required to be inside the gas tank to recycle the unused fuel
Jul 31, 2010 | Homelite Garden
Line for fuel filter rotted out. need to replace tank assembly
No tank replacement is nessesary if its not cracked. Only the lines need replaced, The lines are oversize from the holes so the tank is sealed. If one line is bad they all are bad.
Oct 21, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Dry rotted tubing on my weedeater blower.
Have it replaced at a lawnmower repair shop.
1.) Have them check the grommet (black round rubber like a thick coin with 2 or 3 holes), replace it if it is crumbly. It holds the fuel line and the fuel vent line - if your trimmer has it. Grommets on the average cost about $6.00. Not all trimmers have fuel grommets, some of them only have holes right on the fuel tank. 2.) Replace the fuel line with Tygon fuel line hose. Tygon can withstand UV light, petroleum, high and low temperatures while retaining its shape. Just make sure the replacement tube is of the the same inside diameter. For a small piece of Tygon hose, ave. cost no greater than $8.00. 3.) Replace the fuel filter. The one inside the tank, connects to the end of the fuel line. Fuel filter, good ones are about $4.00.
Aug 23, 2009 | Garden
The fuel lines have rotted out of the edger gas tank. How do I fix or do I need to replace entire tank with new fuel lines?Since there are no male fuel line connections exiting the fuel tank and just two...
Jul 12, 2009 | Poulan Pe550 Gas Edger
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Fuel lines rotted replaced them. carburation is off how do i reajust the carburator it has two small ajustments side by side and one large ajustment above it i think the one large one is the idle screw i...
large adjustment is the idle
if it is a zama carb then 1 turn out each
if it is a walbro carb. 1and1/4 out each
preliminary adjstments they will have to be tweeked after its running or maybe not
Jun 10, 2009 | Craftsman Garden
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Poulan Pe550 Gas Edger Logo
78 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
