Question about Hotpoint Ultima WDM73 Front Load Washer / Dryer
Close door error on display when door is closed on WDM73
Hi, I have a Close door error on the display with the door closed, on my hotpoint WDM73 washer/dryer any ideas whats wrong
    President:
  • 2,692 Answers
Th eswitch that teel it that door is open is out of position or bad.
Posted on Jun 19, 2009
  • 1 more comment
  • Sue Furnell May 12, 2014
    I HAVE THE SAME PROBLEM HOW DO I FIX IT PLEASE
  • Thomas Smithbrother May 12, 2014
    See if the drier operates when you hold the switch closed with your finger. If it now operates the adjust the door or the switch so that the switch
    is closed when door is closed. If the does not work change the switch, or try jumping it out just to confirm it to be the problem. .
Ultima WD860 - dryer has been stuck with 1 minute left for about half an hour. Have turned it off but obviously my stuf is stuck inside.
Hi!
Please disconnect your WD860 from the power supply. The door lock uses electrical power to stay closed. After you unplug the machine from electrical power, just wait a couple of minutes and the door lock will be released.
Regards,
Bogdan
Aug 26, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint wd860 leaks water but cannot find where its copming from all hoses are fine
open door and caerfully check right round the door seal this is very common on these machines.if ok unplug mach remove lid and check the hose from soap dispencer and tub this sometimes splits .cheers
Jun 08, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
My Hotpoint wdm73 won't drain. how do I fix it?
  1. You will need to gain access to the drain pump through the bottom of the Washing machine. Remove the Drain hoses from the pump, clear any debris, change, etc. If it is clear, or the error continues after clearing, replace the drain pump.
  2. If you replace the drain pump and it still won't drain, you will need a new Control Board.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Washing machine wont start - close door message
Hi.
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Ultima WDM73 Front Load Washer / Dryer Logo
304 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
