LG tv locked in hotel mode
M#42LC5DC-UA, bought from hotel but its locked in hotel mode, need to reset to factory, how?
  • 267 Answers
SOURCE: need to get into the service mode for LG 42LC5DC
TAKE THE UNIT TO A AUTHORIZED SERVICER
Posted on Mar 27, 2009
  • 325 Answers
SOURCE: Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
Posted on Sep 01, 2009
57 varieties
  • 1653 Answers
SOURCE: I bought a 32LC5DC Lg
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Posted on Oct 01, 2009
  • 5 Answers
SOURCE: how to unlock lg tv 42lc5dc (input not available)
Is there a unit pluged into the AV ports, most of the new models won't show any AV until there connected
Posted on Jan 20, 2011
  • 139 Answers
SOURCE: I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Posted on Jan 07, 2012
How do I do a factory reset and master reset
Try finding a U tube video on how to get it out of hotel mode or go the the TV manufacturers website to get the operators manual for your model of TV. You may see a section on the setup menu to turn hotel mode off.
Dec 21, 2015 | Televison & Video
How to factory reset LG plasma tv model 42pn4500-ua
To do a factory reset, you have to enter its service mode option. But; to enter the service mode option; you should have its factory remote control [service remote control]; not the remote control you have got with the set. To buy this remote control, contact the authorized service center for LG.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 03, 2015 | LG Televison & Video
How can i factory reset a hotel lcd television with no factory reset opition?
You need a TV remote to select the input source from TV antenna signal.
Jul 12, 2014 | LG 42LC5DC 42 in. LCD Television
Factory reset tv model number 42LC5DC-UA
To do a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Mar 14, 2014 | LG 42LC5DC 42 in. LCD Television
How do i access setup/screen functions?
Visit this site named 'Electro-help". Service mode entering proceedings to many brands of TVs are described there in detail. Check this link, and select the site named above. Pull up older posts there.
Jul 26, 2012 | LG 42LC5DC 42 in. LCD Television
How to unlock lg tv 42lc5dc (input not available)
Jan 20, 2011 | LG 42LC5DC 42 in. LCD Television
I bought a Panasonic 42" Plasma th-42pwd8 from a hotel. The monitor had the menu, and channel buttons disabled through "Hotel mode". It did not come with a remote. How do I unlock the buttons?
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
May 15, 2010 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
Jun 08, 2009 | Televison & Video
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
