Question about Sewing Machines
How to open gateway sx2110g-uw23 tower to replace hard drive
I would like to change the hard drive in the gateway sx2110g-uw23 tower, but I don't know how to open the tower to locate the hard drive
Singer model 478 does not pick up bobbin thread,lower belt around 3 gears does not turn under power. What do I need to Know?
There is a shaft that runs from the top of the machine to the bottom, in turn driving the bottom gear and belt. Though it is hard to see, you will probably find that the gear at the top of that shaft has the teeth broken. It is not impossible to change but definitely difficult.
Apr 09, 2017 | Singer Sewing Machines
How to change a belt on sewing machine
Google is your fried in such cases Mary :>) I can probably find you your manual if you give me the model number.
  • How to Replace a Sewing Machine Drive Belt - YouTube www.youtube.com/watch?v=8Voq7f5vT6E
    • BY SEARS PARTSDIRECT
    • 1 MIN
    • 23K VIEWS
    2015-04-23 · Video embedded · ... shows how to replace a broken drive belt in a sewing ... a broken drive belt in a sewing machine. ... to Replace a Sewing Machine Drive Belt
  • Brother Sewing Machine Diagram to Replace Belt ? ' Yahoo ... https://answers.yahoo.com/question/index?qid=20090426184749AAQ5W2y
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-26 · Best Answer: I am sure there are the diagrams you are looking for are online. ... After years of machine maintenance I would love to have a duplicate ...
  • Videos of how to change brother sewing machine belt bing.com/videos 2q==Click to view 43:10HD Brother PE770 repairs, motor belt.(Spanish Discription) YouTube zClick to view 1:00HD How to Replace a Sewing Machine Drive Belt YouTube 9k=Click to view 1:03:43 SINGER 95-1 BELT REPLACEMENT & RE-TIMING 081813 YouTube 2q==Click to view 1:42 How To Install Antique Singer Sewing Machine Belts YouTube See more videos of how to change brother sewing machine belt
  • Brother PE770 repairs, motor belt.(Spanish Discription ... www.youtube.com/watch?v=Cy-wNw8_kuU
    • BY VINCE J. ARCURI
    • 43 MIN
    • 25K VIEWS
    2013-05-19 · Video embedded · Brother PE770 repairs, motor belt. ... In this video I am showing how to access the machine's motor drive belt. ... Brother Sewing Machine ...
  • Can U Help Me Find A Diagram to Replace Sewing Machine ... https://answers.yahoo.com/question/index?qid=20090428210336AAvwslh
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2009-04-28 · Can U Help Me Find A Diagram to Replace Sewing Machine Belt ? ... I can get a Diagram that can show me how to replace a belt on a Brother Sewing Machine ...
  • Replace Belt ' Brother support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=mfcl8850... Replace Belt. Follow the steps ... Close the front cover of the machine. Reset the belt unit counter. Press (Settings). ... please contact Brother customer service:
  • How to Replace a Sewing Machine Belt ' eHow www.ehow.com > Crafts > Sewing & Textile Crafts > Sewing
    • BY RUTH O'NEIL
    How to Replace a Sewing Machine Belt ... When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; ...
  • Sewing Machine Belt Sizing - Sewing Parts Online ... www.sewingpartsonline.com > Home > Maintenance & Repair Home Maintenance & Repair Sewing Machine Belt Sizing. ... How to Replace Sewing Machine Gears December 5, 2010. How To Replace A Sewing Machine Motor May ...
  • Brother Sewing Machines and Accessories: Rubber Drive Belt https://www.brothermachines.com/sewing/491/Rubber_Drive_Belt Brother sewing machines, parts and accessories ... Brother Emb. Cards; ... Home Sewing Machine Rubber Drive Belt
  • Sewing Machine Belt - Sew-Classic shop.sew-classic.com/Belts_c3.htm Click here to download for FREE How to determine the correct belt size and how to adjust/install a sewing machine belt. ... Sewing machine motor belt ... Brother Elna ...
  • Sewing Machine Repair Tips: Change / Replace The Belt on a ... sewingmachinerepair.blogspot.com/2008/01/change-replace-belt-on... 2008-01-27 · Although it may initially look complicated to change the long leather belt on a ... brother sewing machines. April 27 ... cover over the belt on the sewing ...
  • http://www.bing.com/search?q=How+to+change+brother+sewing+machine+belt+&qs=n&form=QBRE&pq=how+to+change+brother+sewing+machine+belt+&sc=0-42&sp=-1&sk=&cvid=B1D6E61981414EB7A56CB3A4C0D371A3
    Jun 18, 2016 | Brother Sewing Machines
    I have a sewing machine but i have lost the bobbin cover
    Put a piece of thick plastic over the opening, and tape it down.
    This will keep the bobbin in place while you get a replacement,as this is only a temporary fix.
    Apr 09, 2013 | Sewing Machines
    How do I change a pfaff 1222 presser bar lifter? I ordered a replacement part, but now I don't know how to remove it.
    If you are lucky, your part will come with instructions. Each machine is a bit different but basically you have to get into the needle bar/presser foot bar area. If you are Lucky you can get to the lever assembly without having to take out a bunch of bars. But I've only ever seen that once on an industrial machine. So you take out the presser foot bar... to get to the lever. Use caution. You want to be sure you know where and how the parts fit in there. Take your time... take pics or make notes.
    Good luck
    Nov 17, 2012 | Sewing Machines
    I need a light bulb for the BL5260d
    I don't know why it's so hard for you to find parts for your Babylock Serger. There are many online vendors who provide parts. Here's one link that has bulbs.
    http://www.sewingpartsonline.com/Babylock-BL5260-serger-machine-parts.aspx
    Aug 15, 2012 | Sewing Machines
    E6 message on brother CS 6000i
    Needle Position Sensor is disconnected
    This sensor detects the drive timing for the pulse motor for
    zigzagging and feed, the vertical stop position for the needle. It
    detects the upper shaft angle of rotation using a shutter attached
    to the upper shaft and an optical sensor.
    See HERE for Service Manual
    Nov 10, 2011 | Brother CS6000i Computerized Sewing...
    Intermittent floppy disk drive for Husqvarna Viking Designer 1
    These 3.5-inch floppy disk drives are never produced by the manufacturer of the device, but by one of a few floppy disk drive manufacturers (usually Sony) and as such, should your disk drive start to fail, you may be able to disassemble the case of the Viking Designer 1, remove the floppy drive, and insert another standard floppy salvaged from a tower-type PC, thus fixing the problem.
    Since 3.5-in. floppy drives are becoming more and more scarce in modern computers (in favor of CD-RW drives) you may have a obsolete tower computer (remember Windows 98?) in your basement (or your friend's basement/yard sale/flea market/www.Craigslist.org/www.eBay.com) that could supply a useable FDD (floppy disk drive).
    Oct 04, 2011 | Husqvarna Designer I
    Thread bunches up under material
    What you're getting is called a bird's nest, and it's a frustrating pain. There can be a number of problems. First, try changing your needle. It may look fine, but it could be ever so slightly bent and causing a problem. If this doesn't work, take the fabric out of your machine. You'll need to manually turn the machine's wheel and watch through the window at your bobbin. Is the thread hanging up on something in the bobbin area when you're turning the wheel and creating a mess of thread in the bobbin area? Look at where it's catching in your bobbin. You may have a cracked bobbin case-this you can get a replacement for online. Look on eBay for your machine model. They're fairly easy to replace and I can help you with that. If the thread is catching on something else in the bobbin case, be VERY CAREFUL poking around! Don't be forceful with anything!
    You could also have a tension problem with you're upper tension. You may be working with really thick fabric, too. It's a little hard, because I don't know what else is going on. Try some of this, though, and leave me comments. I check back daily and leave me some more details if these things don't help or if you need to replace the bobbin case and need more help. I'll get back to you within 24 hours normally.
    May 04, 2011 | Singer Sewing Machines
    I Have a Singer/Futura. While I start to sew the it flashes E1. Don't know what it means. I don't have a booklet.
    Go to www.Futura-support.com. You can download a manual there and then you'll have a better chance Since I don't know which Futura model you have, it's hard for me to tell you what the E1 message. means. Find your model on the website and download the appropriate manual. That should give you the answer you need.
    Apr 26, 2011 | Singer Sewing Machines
    Husqvarna designer 1 floppy drive to usb
    First you need the USB upgrade kit that has the connectors and parts to change the cover of the machine.
    Next, you will need a new main circuit board if your machine was made prior to about 2006.
    At this point, the cost of parts is about $489. If you can get someone to install these for $10, you can get this done for under $500.
    Otherwise, go to an authorized Husqvarna Viking dealer and check into trading your Designer 1 in for a Designer SE. You will then be able to plug in an external 3.5 floppy drive to read your old disks, a USB stick, or plug directly into your computer and read them from the hard drive (an upgraded Designer 1 can read ONLY from the stick). Used Designer SE's are very reasonably priced since the introduction of the Designer Diamond as the new top of the line and you may be able to get a full manufacturers warranty on the gently used machine.
    Apr 07, 2009 | Husqvarna Designer I
    Sewing Machines Logo
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Chris Wetmore
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
