Question about Maytag 24 in. MDBH965AW Built-in Dishwasher
Maytag Dishwasher MDBH965AW No Power
Unit has been in service for three years with no problems. Then just all of a sudden the unit gives indication that power has been disabled. The AC outlet has been checked and verified that electricity is available. The display panel is dark and non-functional. What could be the issue?
  • danial_peck Jun 19, 2009
    Already did that. Just not getting power to the control panel.
  • Thomas F. Schneider May 11, 2010
    Start tracing the voltage. Is it available at the other end of the cord? Where does it go from their,etc.
  • 6,784 Answers
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
Posted on Jun 19, 2009
  • Michael Masters
    Michael Masters Jun 19, 2009
    Ok, gain access to the control and, check the wiring on the back side of the control. if the wiring harness is in good condition and, connected properly, this will confirm a dead control board. replace this dead control in this case.
  • Michael Masters
    Check the back side of the control for discolorations as well. this will be a sign of a heat related injury or, damaged circuitry.
I have a Maytag Quiet Series 300 dishwasher that is approximately 2 years old. It has been working fine up until now. It has no power at all, no lights etc. I have checked all the power breakers and...
This dishwasher does not have an internal fuse in it unfortunately. Check for power to the dishwasher and if it definitely has 120 volts you need to order and replace the touch control at the top of your door on the dishwasher. This part common fails and cuts power to the entire unit.
http://www.appliancerepairlesson.com/
Good luck
Mar 02, 2011 | Maytag Dishwasher
My dishwasher does not allow me to enter any control inputs on the panel. 'i might be the interlock on the door switch, because it came on once. Does the door interlock disable all control panel...
I don't know about the door interlock, But I would unplug the power to the dishwasher or turn off the breaker to it......Some times the microprocessor gets locked up just like a computer By shuting the power off and turning it back On can reset it. It's worth a try I don't know if this will help but is what I would do if it was mine........
Feb 01, 2011 | Maytag 24 in. MDBH965AW Built-in...
My dishwasher has water going in to it and it drains but it's not making it to the arms, my dishes are still bone dry after all cycles even pre rinse.
it appears ur wash motor is not running.try this-start the unit and let it run for 2 min( this is the water fill period) and after 2 mins u should hear motor running and water splashing sound.u can even open the door and look for water falling from the spray arms.but after 2 mins if u hear only a humming sound and no water splash sound then motor is bad and needs to be chgd.drain motor is seperate for draining the water.
Aug 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
No power indiction lights
yeah! most of the time it is the control panel. but still u want 2 chk the door sws and any burn signs on the control board.
Aug 18, 2009 | Maytag 24 in. MDBH965AW Built-in...
Maytag Dishwasher MDBH965AW will not power.
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Wont run a cycle
Watervalve open?
If yes?
Has this unit an integrated waterstop with the hose interlocked with a flow detection device? Mine failed on that. Bought a new machine after 10 year of service the flow device was 300 dollars.
Apr 04, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Makes growling noise during the wash cycle. some vibration. unit is 6 or 7 years old. it is a maytag jet II EQ. cannot locate the model number as it is a built in unit. would appreciate any help. thank you
Hi Spacepaint, No manufacturer hides the model/serial number behind the enclosure. Look closely on the side of the door panel edge and on the inside edge of the door jam. You will find the model number there.
Growling that happens on every cycle normaly indicates either debris in the sump area / filter or a failing pump motor. Remove screws and inspect the well area for debris.
Recommend a service call if problem is not resolved by the cleaning.
Mar 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
Maytag MDBTT79AWW dishwasher fills and nothing else. Once filled you hear a click, followed by a humming sound for 3-5 seconds, then silence. This will happen two or three more times, and then unit will...
That sounds like the motor trying to start but being jammed it is shutting off via an internal breaker. Check for something in the bootom of dishwasher that might have gotten down there that could do this. You might have to take the sprayer off and some things below that.
Mar 04, 2009 | Dishwashers
Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Feb 15, 2008 | Dishwashers
Maytag 24 in. MDBH965AW Built-in Dishwasher Logo
262 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
