Question about Cleanforce Electric Pressure Washer: 1400 psi 1.4 GPM Aluminum Axial Cam CF1400
Electric power washer won't turn on
No power
Washer won't turn on
you have to check there power supply cable...and power on button..step down transformer on the pcb....7805 and 7812 power regulater ic
May 22, 2013 | LG WM2140CW Washer
No Pressure
Same problem here. Machine still looks brand new. Absolutely no nicks in the hose. Electric power is just fine. I hear the motor, then when I squeeze the trigger, I get a weak dribble of water for about 5 seconds, then the motor is quiet for a while. This sound familiar to you? I just posted my similar problem. If you hear anything useful, please forward it to me : reb49@att.net Ron
Apr 30, 2013 | Task Force 2000 PSI Electric Pressure...
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
Pump won't run
Did you figure this out yet? If not.
Did you check the onboard GFI breaker switch?
Did you make sure the water was connected and turned on?
Jul 11, 2012 | Stanley Portable 1600 Psi Electric...
My marcher m520 electric water blaster stopped working as if it has blown a fuse but when I remove the cover I cannot see any sign of a fuse. Do they have one and if so where is it located. Thanks Pete
is there i ground fault switch at the power cord plug . if there is reset it . another problem with electric pressure washers is if water can't pass through wnd and nozzle they won't operate. there ian't a fuse inside unit.
Sep 24, 2011 | Alfred Karcher K 5.93 M Electric Pressure...
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
Cleanforce Electric Pressure Washer: 1400 psi 1.4 GPM Aluminum Axial Cam CF1400 Logo
81 people viewed this question
Top Cleanforce Garden Experts
Dennis Key
Dennis Key
john h
Are you a Cleanforce Garden Expert? Answer questions, earn points and help others
