Question about Acer Aspire 3000 Notebook
Display problem The Function key to adjust the brightness won't go bright enough. LCD, Inverter, Motherboard ?
  • 324 Answers
Could be either the LCD backlight or, more probably, the inverter is going bad. Would doubt that the LCD, itself, is going bad.
Hope that helps and have a super day!
Posted on Nov 07, 2007
I have a lenovo t420 which has brightness/dim issue and can't correct it by unchecking the auto brightness
There should be a function key to adjust the brightness at the top of your keyboard my laptop is F2 or F3 so at the bottom of the keyboard is a key label FN The Function key looks like a sun with an arrow if you are lucky to have it labelled.
If this does not fix problem you may have a faulty laptop . There is a circuit called an inverter in your laptop that converts DC to a higher voltage AC to run the fluro backlight behind your laptop's LCD screen. If this inverter goes faulty you could experience the symptoms you are seeing. This would require a replacement of the inverter circuit board in your laptop by a repair service centre.
Sep 05, 2014 | Lenovo ThinkPad T420 Notebook
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
I have a hard time seeing my screen in XP - where do I go to adjust the brightness of the screen
How hard a time is it? Maybe your screen is going bad or the LCD Inverter is bad.
Press and Hold the FN function key located at the lower left portion of the keyboard then hit the key that makes the display brighter or darker. There will be one key for brightness and one key for darker. Normally it will have the icon of a sun or washer with the up or down arrow.
Apr 27, 2012 | MSI MegaBook Computers & Internet
Hi my sony vio vgn txn 15p video is faint
If when you say faint you mean you can barely make out an image then the problem is most likely the backlight inverter in the screen assembly has gone bad. If what you mean is that the brightness got turned all the way down then it's just a matter of adjusting the brightness of the screen by holding down the function key (Fn) and pressing the LCD screen brightness adjustment keys noted usually by a picture of a sun or something similar accompanied by an up or down arrow.
Dec 09, 2010 | Sony VAIO VGN-TXN15P/B Notebook
Lcd lights got dimmer
First check to make sure the power adapter is connected to the laptop properly, if not it runs off the battery and the display is dimmer.
Second check the brightness setting, you can adjust the brightness by pressing the Fn key plus the F7 or F8 keys to adjust the brightness.
If this doesn't work then :-
The problem/fault could be one of several things. Could be the CCFL lamp, the inverter that supplies high voltage to the CCFL lamp or the video card.
The video card cannot be replaced on a laptop, it is part of the motherboard.
To determine if the video card is faulty, connect an external monitor to the external video port on the laptop, power up the monitor first and then the laptop. The video output will switch automatically to the external monitor, if you see a normal Windows image then the video card is OK.
Next, shut down the laptop, disconnect the monitor and power up the laptop. After the laptop boots up look at the LCD screen at a sharp angle and if you see a dim or dark image then the fault is a faulty CCFL lamp or inverter. Most likely the CCFL lamp is faulty, but the inverter is easier to replace.
Check out LCD Parts WEB site for service, parts and DIY info. Use this link.
Aug 11, 2009 | Compaq Presario M2000 Notebook
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Laptop inverter problem
you have major problem here - the power regulator on the motherboard which regulates the line voltage down to 12V to feed the inverter, and battery voltage /up/ to 12V to do the same, is blown. I've seen this happen in HP laptops - line voltage to the inverter on mains power reads at 18.2-18.5V (which overloads the inverter), on battery it reads 10.5-11 (which won't fire the inverter). This is usually a sign of a bigger problem. Usually one that involves replacing the motherboard.
Dec 03, 2008 | Dell Inspiron 9400 Notebook
You have a blue key that says FN (stands for function) on the bottom left side of your keyboard, next to control and shift. The brightness and dimming hotkey is usually on the arrow keys or up on your f row, f1-f12 and you'll see like a sun and half sun in blue, same as the function key. While holding that function key tap keys you found and it'll brighten and darken. If it doesn't, you may need hotkey software installed, a new LCD (backlight may have failed) or inverter which powers the LCD.
Oct 26, 2008 | Toshiba Satellite A25-S207 Notebook
Acer aspire 5043wlmi laptop starts but know function of lcd but works on desktop monitor
The computer's power management system automatically dims the screen when using battery power, which is one of the power-saving features.
To adjust the brightness:
  • Hold down the Fn Key located at bottom left of your keyboard next to the Ctrl key, and adjust the screen brightness using the left/right arrow keys located at the bottom right of the keyboard.
If that's not it then
A dim or dark screen does not necessarily mean a bad inverter! It could be a faulty lcd backlight bulb, inverter cable, inverter, or in some cases a motherboard failure. If your still under warranty then I would get Acer support on the phone and see what they can do.
An Inverter converts direct current (DC) to alternating current (AC).
Jul 01, 2008 | Acer Computers & Internet
Adjust brightness
if its a laptop the problem should be from the pcb inverter at the back change the inverter for a possible improve ment
May 26, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3000 Notebook Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
