Question about Pride Revo 4 Wheel Scooter
Batteries not charging - Pride Revo 4 Wheel Scooter
    Habit-Forming:
    New Friend:
  • 88 Answers
1 dud batteries?
2 dud charger? Borrow another
3 has a 10 Amp fuse hidden under the floor mat and inspection hatch below blown. Pride don't want to tell you about thevtwo fuses down there.
Posted on Jun 02, 2016
Polaroid rechargeable batteries in duracell charger
The problem isn't the brand of batteries Vs. charger; the problem is the electrical rating of the charger Vs. the charging specifications for the batteries. First make sure that the batteries are the correct type; i.e., nicad, lithium ion, etc. Do not try to recharge alkaline batteries. Your batteries have a mili-amp hour rating either shown on the battery or in the manufacturers specifications that are available on line. Each battery type also has charging specifications. The battery charger is designed to provide a specified charging voltage and current to the batteries and those specifications must match the battery's design. Using the incorrect charging voltage and current can cause the batteries to overheat and even explode.
Mar 18, 2014 | Polaroid I531 Battery (Equivalent)
Tip
Keep NiMh batteries fully charged?
NiMh batteries lose charge quickly after a 15 minute charge. Keep the batteries in the charger so that trickle charge keeps the float voltage up to maintain fully charged state until you have to use the batteries.
on Aug 14, 2010 | Cameras
Charging problem the red light and green light or both on when charging and the batteries don't seem to be charging
sounds like the batteries are dud, most chargers have 2 or 3 lights, red (max charging) Amber (battery nearing full charge) Green (fully charged and most will switch to a trickle charge) has the scooter been out of use for some time as scooter / wheelchair batteries must be kept charged, and only a short time of no use can destroy the batteries.
Sep 09, 2013 | Golden Technologies Companion II Travel...
Cobra Micro Talk PR4750WX.New rechargable batteries will not charge in provided charging cradle.
The original Sanik batteries have a negative side with about ten mm of metal showing on the side. Trim the plastic off your new batteries to match and the cradle charges again.
Dec 11, 2012 | Cobra 22 CHANNEL 2-WAY RADIOS
Batteries do not charge
If your batteries aren't charging than they just might be old. Rechargeable batteries don't last forever. Also if you charge them whenever they are not in use they're lifespan will shorten. You might just want to consider new ones.
Cheers
Mar 06, 2011 | Video Game Consoles & Games
Kodak digital camera not charging/ indicator not shown while plug in charger
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
Jun 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
Can I charge only 3 batteries in my Quantaray 4 batery charger?
yes,the charger will charge three batteries at a time if you like. three batteries will charge faster than four batteries. you can even charge one battery by itself.
Apr 03, 2009 | Cameras
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Pride Revo 4 Wheel Scooter Logo
51 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
