Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Steering My tractor has a steering problem. The left front go striaght and the right front turns.
If not tie rods could be one of the spindles is broken. I just had to replace my front left spindle, it is what actually turns the wheel, steering rod connects to the spindle which is also the part that goes through center of wheel. Hard to explain much easier to show picture & diagram. I have an older wheelhorse mower & don't know if the bodies & parts are similar to other riding mowers.
Posted on Sep 20, 2012
  • 376 Answers
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Posted on Jun 19, 2009
My 1957 ford 601 is very hard to steer to the left but fine to the right. Whats wrong
I believe someone driving the tractor has hit a hole or an object hard enough to stop the tractor and literally spun the steering wheel all the way to one side, thereby bending the spindle or the link connecting the steering box to the spindle. Drive the tractor straight on level ground, stop and get off then look standing at a 25 yard distance in front of the machine looking at the symmetry of the front wheels. That will reveal spindle problems.
Dec 18, 2014 | Ford Garden
Can t turn stearing left or right takes all my strength to turn
check out the steering connecting rod. its the rod that goes from left to right front wheels. if it is not completely straight, either bend it straight or buy a new one.
Also, could be your front axle if you dont have the cast iron heavy duty axle.
Jun 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steering, The right front axle and tire lean in as if I were turning the steering wheel in the left direction but the left axle and tire remain straight. If I turn sharp to the left the right tire turns...
1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
2) while you are at it, replace the front wheel bearings on both sides
Aug 07, 2011 | John Deere Garden
Steering locks when turned ti extreme left or right
If your steering lock when turning extreme is because the ETO busher on the front axle is wear out. Try replacing it. It is on the end of the axle.
Thanks.
Jul 18, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Turns fine to the left but will not turn right past going straight.
check your steering linkage on the front side by that right hand wheel, is it bent or being restricted? Even check up and down on the steering wheel column itself.
Aug 13, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When turning to the left the tractor turns very
Dan, A couple of things to look at and perhaps adjust. First look at your drag link to see if it has somehow gotten bent. If you want to see a good clear picture of what is should look like, you can go to jdparts.deere.com , click on "parts catalog" on the left side of the page then enter your model number then select "sectional index" then steering wheel. If the drag link appears to be in its natural shape and the threads are not stripped on either the ends of the rod or the ball joints, you can adjust the ball joints to either lengthen or shorten the rod thereby changing the amount of steering in both directions. If the drag link is on the left side of your tractor, lengthening it would give you more throw to the right while giving less pull to the left.
Another thing to look at would be the pivot point of the front axle. Raise the tractor up and check the amount of front to rear movement in the front axle, there should be almost NONE. If there is a lot of front to rear rotation in the axle, you will need to look at the pivot pin and the bushings. Again refer to the jdparts catalog and see front axle.
As far as design, this is one of the better designed steering systems on lawn and garden tractors in my opinion. They are much more solidly built than most any of the other brand names out on the market.
Hope this helps you out and if you do purchase the tractor you should get many years of good dependable service out of it as long as you keep it maintained.
If you don't get one with it, I would suggest going to your local John Deere dealer and investing in an Owner's Manual for it. In the future it could be money well spent just from the information contained in the manual.
Oct 24, 2009 | Garden
JD 2030 power steering failure
either the steering arm in the bell housing on the right side of the tractor is striped or the colume is broken internaly. the is asuming that all tie rod ends and the bell crank are still atatched.
Jun 16, 2009 | John Deere Tractor Side Screen...
1953 Ford NAA tractor hard to steer. When small front end loader is full I cannot turn left.
Hi..my name is Keith..and i restore 9N's,2N's and 8N's..and i have dabbled with NAA's and others..but i would suspect its in the steering box..and i suspect its the left sector gear(steering gear) is worn or has a bad spot on a tooth..i would jack the front axle up and suport it with jack stands and operate the steering wheel and see if i could feel any binding in the steering box or in the front wheel (Left and Right) axles ..and i would also check the tierod ends..i hope this has helped..if not..please write back
May 26, 2009 | Ford Tractor Naa Golden Jubilee Emblem
Turns left sharply, barely turne right
The problem is either that there isn't enough range on the steering gear in the right direction, enough length on the steering drive rod (going to one front wheel), or a bent tierod (connecting the 2 front wheels) or worn tierod bushings.
Most likely is the tierod. I do not like how these are designed so for my own tractors I make one using tierod ends available from tractor supply company, grade 8 bolts and steel tube with a 3/4" inside diameter. A bit of measuring and welding later the steering is better than new.
May 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
680 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
