Question about Wolfgang Puck Kitchen Appliances - Others
Grill just stop working after left on awhile
Overheated now want turn on
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
The grill will not light. The firt burner will
if the burners are fairly new , not old and full of rust, yes, it is the regulator if you are using tanks.
Jul 05, 2009 | Grilling
32" niko lcd-green pixelation
This is probably model OTP-311W. Problem is caused by overheating. Air flow is restricted by plastic grill over fan in back of unit at middle top. To fix, remove four screws retaining grill and fan. Take off grill, leaving fan in place. Replace screws without grill. I had same problem. Since removing grill, have now run unit for over 72 hours without pixelation problem.
Jun 21, 2009 | Niko OTP-3211W 32 in. LCD Television
Trying to remove service grill for Nutone QT140L combo fan/light
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
Jun 02, 2009 | Broan-NuTone N-QT140L Combination Light...
Gas grill overheated
I might have an Idea to what happened. All grills have a drip pan, most all new grills have a drain for grease that falls from our savory meats. Well, if, (not saying that you haven't) but if, you have not cleaned the drip pan, there is still grease left over that gets absorbed by food droppings. IF this is the case, you had a ticking time bomb of a grease fire. The grill did not overheat, the grease caught fire. You said your grill was a year old; so the regulator did not go full blast and when they do go bad they do not let gas pass through.
Not trying to preach to no one because I have done it myself, never leave your gas grill on and unattended. I hate to say it but even the owners manual says it.
I hope I did not come off the wrong way and I hope this might give you an idea/thought of what happened.
Sep 26, 2008 | Thermos Stainless Steel Gas Grill
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Foreman Grill GR36CB stopped working
Foreman grills have a fuse on the circuit board, have you popped that section open to visually check the fuse? It could be that simple. Fuses do wear down over time, so depending on how much wear and tear you put in, it could just have broken on its own.
Of course, if you replace the fuse and it still goes, you'll need to double-check to see what's shorting it out. The unit may be dead but I wouldn't bet on it.
Nov 08, 2007 | George Foreman GR36CB Indoor Grill
Kitchen Appliances - Others Logo
Top Wolfgang Puck Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
eyecam
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
