Question about Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas String Trimmer TB575 EC
Remove cutting head assembly from TB575 EC String Trimmer
I need to know how to remove the cutting head assemble from the specified string trimmer
4 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: Tb70ss gas trimmer.]am trying to
I assume you can get it assembled, but you aren't getting the right recoil action. Before you put the end of the rope through the hole to put a handle on it, you need to preload the spring a bit by turning the spool 3 to 5 turns in the direction that would push the rope out through the hole. As you do this you will be winding up the spring. Then put the rope through the hole and put the handle on it.
Posted on Aug 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need a manual for
Go to this link:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10001
Enter your model and serail number and download the manual.
Thanks for choosing FixYa,
Kelly
Posted on Aug 25, 2011
davidgrog30
  • 136 Answers
SOURCE: I have a troy built tb575 ec and when I put it in choke 3 postion and press the throttle is cuts off
Get someone to thoroughly clean out the carburettor. Sounds loike main jet blocked.
Posted on Jun 09, 2012
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What oil weight is used in the TB 575
If it is a 2 cycle motor, then use an appropriate 2 cycle oil. I use a synthetic oil that 1 bottle is mixed with 1 gallon of fresh gas.
May 09, 2014 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
Remove the trimmer head from shaft
The entire trimmer assembly (from the gearbox forward) will slide off of the drive shaft cover. On the side of the aluminum gearbox assembly, you will find a single screw. This is the "anti-rotation screw" (do not lose this). Then remove the small (approximately 1" diameter) clamp from the end of the gear box assembly and simply pull the entire cutting assembly off of the shaft.
If you just want to remove the trimmer bump head assembly, then you will need to lock the bump head assembly to prevent rotation while you are working. If you purchased this new, then there should be a small metal rod included with your accessories. This will fit in a small hole in the base of the gear box assembly 791-182193 and prevents the trimmer head from rotating.
Then proceed to remove the following items:
791-180814B (replaces 791-180814) Bump Head Knob Assembly
791-147495 Inner Reel (hold the trimmer string)
791-610636B (replaces 791-610636) Spring
791-612026 Retainer (be careful removing this so you do not inadvertently destroy it). If you intend to reuse the trimmer head. If not, then hack, pry, stab, etc.. until you mangle it enough to remove.
791-683301 Outer Spool & Eyelet Assembly should now slide out leaving only 791-612483
Spool Shaft which I will assume that you want to keep.
I replaced my entire string head assembly a couple of years ago (and subsequently misplaced it and am in fact wanting to purchase one) and replaced it with a grass-gater or similar.
I hope this helps.
Jul 16, 2009 | Troy Bilt Tb70ss Gas Trimmer
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
How do i install more string? Lost manual
I have the same trimmer and I fixed the problem for good by getting a shakespear line trimmer head to replace the original faulty design,it also has 4 line rather than 2 so it cuts better. It costs about $15.00
see link
http://www.lowes.com/lowes/lkn?action=productDetail&productId=120473-42694-14548&lpage=none&cm_mmc=search_yssp-_-Unassigned-_-060209-_-Shakespeare%20Universal%20Fixed%20Line%20Trimmer%20Head
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas String Trimmer TB575 EC Logo
79 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
