Question about Homedics Sound Spa Premier SS-5000 Clock Radio
LL in the temperature display of wireless sensor
Why does outdoor temperature display only show = signs?
The outdoor sensor probably uses solar energy to charge a battery that powers the wireless transmitter. The battery may be defective or the charging circuit may have failed. The instructions that came with the station could provide some troubleshooting tips.
Nov 03, 2015 | Weather Channel WS-8500TWC-IT Wireless...
Model no 217s31 does not display outdoor temperature reading.
As much as it sucks to do, you have to reset the base and the temperature sensor. When you do it, keep the temp sensor next to the base until the base recognizes it.
Mar 11, 2013 | Oregon Scientific BAR386 Wireless Weather...
What does error 5 mean
Error Code 5 flashes = NTC fault open circuit or shorted
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 09, 2011 | Hoover AI130 Front Load Washer
I don't know why my microwaves keep beeping and starts the Exhaust Fan automatically every 5 mins. The display says F-3. Please help me with the problem I'll appreciate.
F-3 is usually for the temperature sensor being faulty. What you need most likely is to replace the temperature sensor. This would explain why your microwave oven exhaust fan keeps going off, because your temperature sensor is telling it that it is overheating even though it isn't.
Jul 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Outside temperature not showing on ll bean model # 9021u-it
Try removing the batteries from both the outdoor sensor and the indoor unit. I had the same problem and fixed it by doing this.
Sep 28, 2010 | Taylor 1528 Wireless Digital Indoor...
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
F-3 displayed
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if wiring is not a problem.
Thanks
Rylee
Jan 15, 2010 | Frigidaire FEF352 Electric Kitchen Range
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
90 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
