Question about Saws
Rotozip rev01 type 1
Won't start
My dad has an old rotozip rev01. we can't remove the blade because the flange nut was overtighten. is there a way to remove the nut?
'Sprag' the blade to stop it from rotating. Apply some WD40 or kerosene around the area and use an impact gun or impact driver to crack the nut. Check the thread and make sure you are actually turning the right way to loosen the nut. Some are a left hand thread! Cheers Bob
Sep 29, 2016 | Bosch RotoZip Spiral Saw RZ10 - 2100
Whereto get manual for roto zip z20
The manufacturer's web site has the manuals for many of their tools on their support page: http://www.rotozip.com/en-us/support/Pages/Manuals.aspx . If you have the RZ-20, the direct link to the manual is http://www.rotozip.com/en-us/support/Documents/WEB2610938267%2002-07%20RZ1-25.pdf .
I don't know of a Z20 from RotoZip. I hope this helps.
Dec 28, 2015 | RotoZip RZ 20 RZ20-4300 Spiral Saw System
I have a rotozip rz20. The bearings are shot. Need to know where I can find a new set. Google has not been any help.
http://www.ereplacementparts.com/rotozip-parts-c-15402.html?utm_source=Bing&utm_medium=PPC&utm_campaign=rotozip%20-%20search%20-%20mike Try here.
Jun 20, 2015 | Saws
When i pulg in an turn on my roto zip model rev01 the lights come on but saw does not, took apart an brushes looks good, what else could be wrong?
depending on how old the saw is, the trigger may be shorted out. try and get into the trigger assembly to confirm.
Dec 19, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
My rotozip RZ20 keyless chuck will not open.
open the chuck and look in the center there is a screw allen type most times or a star screw in the middle that connects it to the drill shaft just tighten it up should work fine then!
Apr 27, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
Saws Logo
32 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
