Question about Pentax Optio T10 Digital Camera
MY T10 CAMERA FLASH IS NOT WORKING, I HAVE REPLACE THE BATTERY WITH A NEW ONE AND THE FLASH IS STILL NOT WORKING. I NEED HELP!
  • Fluffa Jun 19, 2009
    yes my flash is turned on and its still not working. thanks
    Sergeant:
  • 313 Answers
IS THE FLASH TURNED ON ! CHECK IN THE MENU SETTINGS FOR FLASH MODE.
Posted on Jun 19, 2009
I have a flashing E:62:10 warning on the screen
Hi Rajesh,
I have come across this problem earlier , and would seems as a weird thing to do but works, what you need to do , is remove the batteries and hit on the side of the camera with your palm and then try to put the batteries back in and then restart the camera , if that does not work , you need to get it done via the service center as this problem is associated with a gear of the lens and can be corrected by professional tools.
Hope that helps ...:)
Sep 03, 2011 | Sony Cyber-shot DSC-T10 Digital Camera
Sony DSC T10 shows error E: 91: 01. Also flash
1. Turn OFF camera
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Your problem should be solved
Oct 31, 2009 | Sony Cameras
Flash stops working
The flash bulb may be broken. Try contacting Pentax to get it fixed.
Jul 15, 2009 | Pentax Optio T10 Digital Camera
Black photos at nite with flash
It's very difficult to pinpoint an issue with what you've given here. Particularly since flash photography at night can be hit or miss anyway.
I actually wrote a review for Popular Photography & Imaging on your camera... You can read it here:
http://www.popphoto.com/Reviews/Cameras/Camera-Review-Sony-Cyber-shot-DSC-T10
And while I really LIKE your camera, it does have its' limitations, particularly with the flash at night. It's small and not very powerful in comparison to a full-size/feature flash unit. Because of this, here's a few things you should keep in mind when you shoot at night with a flash:
Allow the flash enough time to "recycle". In other words, when the flash fires, it needs to replenish power to make another full-power flash exposure. If you're shooting images very quickly, you may not be at full power for each frame. The T10 has a flash-ready indicator, so make sure it's activated before you shoot your images.
Stay close- There's a thing in photography called the "Law of Inverse Square". Basically, this means that when you double your flash-to-subject distance, your light intensity is cut down to ONE QUARTER of your previous distance. The T10 has a very small flash, so this becomes critical for good images.
Be reasonable in your expectations. The T10- or any other camera-mounted flash for that matter, won't light an entire stadium or something that's more than 10 feet with your flash or 50 feet with a full-power/size flash.
If you're following these guidelines, and you're still having issues with dark images, try upping your ISO to a higher setting to add some sensitivity to the sensor. Doubling your ISO cuts the light required to make a good exposure in half. If you've done this and the images are still black, you may want to take the camera to a repair shop for evaluation.
I shot several photos that should be included with the story on POP's web site, so you can see that the camera IS capible of shooting some nice flash image, but again, were done with an understanding of the camera's limitations.
Hope this helps you out!
Jul 14, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Flash not working
Hi there and welcome to FixYa.
Bad batteries can cause that. The flash module needs alot of power to charge. Your camera will still work, but without enough power to charge the flash module, it may take along time. Again.
Try fresh batteries.
Rob
Feb 25, 2009 | Pentax Optio T10 Digital Camera
Error code E:62:20 meaning
This appears to be a problem with a connector inside the camera. Try:
  • Take the memory card out, clean the bay and the memory card with compressed air
  • Take the battery out, clean it and the battery compartment with compressed air.
  • Some users report that you can 'fix' the problem by tapping it gently on the battery compartment, so that may be worth trying as well.
If these things don't work, it will have to taken to a service technician - it's quite expensive to repair, sadly.
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
E:91:01
easily just reset the camera with a pencil.
Aug 14, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
E:62:10
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Pentax Optio T10 Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
