Question about Casio Computers & Internet
Recovering data flash drive - Casio Computers & Internet
5 Suggested Answers
  • 171 Answers
SOURCE: Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Posted on Jan 25, 2008
brannfenix
  • 81 Answers
SOURCE: My cruzer micro 4gb flash needs compression but I
You can run a data recovery app on the drive and attempt to pull off any data still accessible. I recommend the GetDataBack Data Recovery apps from http://www.runtime.org . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Posted on Aug 24, 2009
Testimonial: "Thankyou! I will try it and post my results."
  • 18 Answers
SOURCE: Flash drive malfunction
Use this data recovery program: http://www.asoftech.com/adr/
You can find it in magazines or on a internet...
It is a simple, fast program which thorough scan the flash drive on computer, which allows you to recover lost files
The program can also use it to retrieve files including photos, music, video, and other type of files.
Posted on Feb 11, 2013
  • 15 Answers
SOURCE: Will the recovery tool recover the data on the jet flash?
That often depends on what you done to this flash drive since the deletion.
In fact, after the deleting process, the deleted data on this flash drive is not actually wiped out as you normally think. It is still stored on this drive and only become invisible. But, it cannot be there forever, since it can be easily rewritten by anything new on the same drive. So, you should take care.
Plunge this drive to your computer and download a flash drive data recovery freeware to help you out:
http://www.freeware-fix.blogspot.com/2013/02/external-hard-disk-recovery.html
I believe this data recovery freeware can work perfectly on your flash drive just in the same way as it completely retrieves all the deleted data of my friend off from his WD external hard drive. Just give it a shot!
Directly download this freeware here:
http://freeware-fix.blogspot.com/2013/02/hard-drive-recovery.html
PS: If you don't want to encounter the similar data recovery problems, you'd better back up everything important well in the future.
Posted on Dec 10, 2013
How to restore delected files from my usb flash drive
Hi, Even I faced the same problem. I have deleted some of the PDF file from my pen drive and luckily I could get all the files from it. I used Yodot File Recovery software and with the assistance of this software I was able to get all the PDF files. Download free trial version of the software if you want to know how to recover a PDF file. It recovers not only PDF file but also all the files present in the drive.
Nov 23, 2012 | Computers & Internet
Lost files in USB memory flash
Asoftech data recovery program can recover data from formatted, lost or damaged hard drive or partition, Ghost hard drive .
# Recover lost, formatted or deleted ( word ,excel ,ppt, office document, video zip, photo files etc ) from hard drive, Support USB recovery and other disk recovery .
Jun 11, 2012 | SanDisk 16Gb USB Flash Drive
I used my sandisk cruzer 8g as a first boot device to load a certain application, then suddenly hangs and power off, after i restart the pc my usb device reads as 0 data, when try to open it asking to...
Hi Amir,not 'Safely remove the hardware' will result in data loss on USB flash drive.However,you can recover your data on it with third party data recovery software.I have succeed to recover data from pen drive with Tenorshare data recovery.It can recover data after deeply scanning your USB flash drive to look for lost data. By the way,you can download a trial version and scan your flash drive for free to preview whether your data can be recovered. http://www.any-data-recovery.com/index.htm
Jun 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I am having one 4gb pendrive its not opening. now im inserting my pc please recover it.
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/index.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
Apr 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My flash drive is faulty and i want to retrieve my data
dont panic, try this data recovery program called asoftech data recovery.
I used the program before, it helped me recover my files from pen drive. If it does not work, you may try quick format the pen drive and then use asoftech data recovery program to recover again your files.
Oct 10, 2008 | Computers & Internet
How can i recover the data from my flash drive after forced to format
Deleting or formatting won't make the data in USB drive erased permanently.
Those deleted data is still stored on the USB drive , it's just invisible or inaccessible. Only the FAT or NFTS table is erased (the information about where those data were saved), but the real data are still intact there in sectors of the hard drive.
So as long as those data are not overwritten by new data, it's highly possible to recover them. And the MOST Effective way is to rely on some format recovery programs.
Try this flash drive recovery program named asoftech data recovery, which can recover data after deeply scanning your USB drive to look for lost data you accidentally deleted or formatted.
Sep 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Nov 08, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
