Question about Pitco Frialator 35CS Deep Fryer
Flames coming out of the flue - Pitco Frialator 35CS Deep Fryer
  • 23 Answers
There is most likely oil/oil residue in the chimney.
Posted on Apr 05, 2016
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
Nov 03, 2013 | Vulcan 1VK85DF Hi-efficiency Gas Fryer...
Flames coming out of top and going into flue pipe
Did you change the orifice and regulator from Natural Gas to LP Gas? IF not, that's the problem.
Dec 27, 2012 | Heating & Cooling
Haywood h400 pool heater, flames coming out of flue
check gas if ok clean burners make sure it is a propane unit if a N in model number it is natural gas orfices incorrect and will overheat very dangerous
Sep 09, 2012 | Hayward H Series Pool & Spa Heater 400k...
I have a goodman high efficiency furnace, model gms9/gcs9. I've had several furnace techs look at it scratching thier heads. It won't fire up, the ignitor comes on but won't flame the unit. I...
check to see that your condensate line is not plugged. next check the p-trap where your line goes in. also check your flue abs flue pipe see as it comes out of roof is it open or does it have an elbow coming off of it i usually install with elbow preferably less water goes in the units resevoir hope that helps u
Apr 04, 2012 | Goodman Heating & Cooling
Pilot light keeps going out after about 10 seconds on my Gazco Riva 67 inset fire.
Most likely it is the flame sensor thermocouple not working. Make sure the probe is right abaove the pilot flame and make sure it is clean and not covered in soot. The probe needs to sense the flame or the gas valve closes. These can be found at almost all harware suppliers and stores.
Mar 08, 2011 | Heating & Cooling
We have a residential Lochinvar Solution Boiler (model RBN090). Around 7 years old. For past 2 weeks pilot light keeps going out. 2 repairmen have come out. We have replaced the Gas regulator, the roll...
Take notice of the wind conditions when it goes out. If there is a draft, the wind can come in the room with the water heat from the flue and blow it out. Or it can come in the room from another way and exit from the flue and blow it out.
May 12, 2017 | Heating & Cooling
Furnace comes on flames up and blower starts then cuts off red light blinks 6 times
try looking at the air filter see if this is blocked, reset overheat button press red top check if fan on the flue is running , check if flame senser is clean or conection is loose , see if that helps
Oct 18, 2010 | Goodman GDS80904BNA Open Flame Heater
When gas wall heater lights a ball of flame comes
Lets get a tech in there to get it cleaned and the gas pressure checked.
Jan 18, 2010 | Off The Wall Heating & Cooling
I have a RM 2811 2 way dometic is operates fine in A/C mode no
Hi there. When calling for cold, flame should be large and blue. If orange, clean mixing tube, flue, chimney. If still orange, adjust "air" inlet on mixing tube to get blue flame.
Thanks
Paul
Jul 13, 2009 | Refrigerators
Toyo 56
Hi ejohn,
There is no valuable, practical adjustment for the flame on a Toyo Stove. A yellow flame can be caused by several things. How old is the stove? When was the last tune-up? A dirty sooty carboned up stove will have a yellow flame. A breach in the flue pipe will cause a yellow flame. An incorrect installation of the flue and exhaust hoses/metal exhaust elbow will cause a yellow flame. In the last scenario, the intake will be hooked to the exhaust and the exhaust will be hooked to the intake ports of the flue pipe. A malfunctioning fuel pump can also cause a yellow flame. The wrong fuel can cause a yellow flame, too. Most likely, your stove is dirty and needs a tuneup. It should have a bright blue flame if it is clean, and operating correctly. You can download a manual at REE, Anchorage through a Google search. If you want a more detailed diagoses, write back and give me more detail and I can help you further. Toyotech
Jan 30, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Pitco Frialator 35CS Deep Fryer Logo
184 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
starztruck4u
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
