Question about Bosch Nexxt 500 Dryer
Dryer keeps turning on after finished
I think it a wrinkle free system that turns dryer on every 10 minutes after dryer is done with cycle.....how do you stop this permanatly
3 Suggested Answers
  • 39 Answers
SOURCE: The dryer has stopped working.
We have the same dryer and found it was the micro switch on the panel that was the problem. Have you read and tried this solution.
Not sure if this will address the problem but it maybe worth a try. We also had problems with our dryer starting but the lint indicator was not on. We found the problem was with the start/stop button; it was not making contact with the mini-switch. Used some hot glue under the lever that makes contact with the mini-switch. Put it back together and works great again. Saved about $260 on new control panel. Removing the control panel was pretty easy for a DIYer.
Unplug the dryer.
Remove the four screws that hold the panel in place. They will be hidden under caps on the housing, Pull off the panel. Be careful because the wires will prevent you from pulling it entirely off but you can pull it from the right corner up and flip it on its back side to expose the back of the panel.
The white wire guard will have to be removed. The wire ties holding the wires to the guard will have to be removed by cutting the ties. Replacement wires ties can be purchased at any home improvement store. Remove the control panel by pushing the plastic clips in that hold it to the housing. There should be 6 and two plastic clips on the right center of the panel. If done right it will easily pull off. If force is needed one or more of the clips have not been disengaged. Do not force it because it is made of plastic and will break.
Once the control panel is removed from its housing, the start/stop button can be identified-last one either on the right or left (can
Posted on Feb 07, 2011
  • 119 Answers
SOURCE: dryer turns back on after cycle is complete
Mike, this is a anti-wrinke function of the dryer. You can turn this function off. Without a full model number I can only tell you to refer to the owners manual to disable the anti-wrinke function.
Posted on Apr 21, 2014
How can I get less wrinkles in my clothes after wash cycle is finished?
I use the dryer to get the wrinkles out. If i have a wrinkled shirt that is already dry and I need to wear it, I put it in the dryer for a few minutes with a wet wash rag.
Oct 10, 2014 | Kenmore Washing Machines
Dryer turns back on after cycle is complete
Apr 20, 2014 | Bosch Vision 500 Series Front-Load Washing...
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Jul 22, 2011 | Miele Novotronic T1515A Electric Dryer
Following the permanent press cycle the dryer goes into wrinkle free mode. This mode seems to stay on for a long time. Is this normal? Thank you. Model #DV350AE
Wrinkle Free is designed to keep running so that unattended clothes do not wrinkle.
You can turn Wrinkle free off.
Feb 20, 2011 | Samsung Dryers
When the cycle has finished and the signal has sounded if i do not empty the clothes right away about 15 minutes later the cycle restarts on its own. I have owned this dryer only 3 weeks and twice i have...
that is most probably a feature of the dryer called wrinkle guard there to keep the clothes from wrinkling until someone gets there to empty them from the dryer.  check your users manual.  it will probably explain it better than i did.
Aug 04, 2010 | Dryers
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
13 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
