Question about Kenmore Washing Machines
My washing mashine just stopped mid cycle and is full of water.
    Problem Solver:
  • 9 Answers
I worked on washer and dryer as a part time job.
And had a lot of question like this one. In almost all cases it was the lid safety switch being the fault. I suggest you open the lid and be sure it is not stuck. Use a pencil to push it down a few time. Corrosion does effect them and not let them work properly. If it does work problem solved . If not you'll have open the lid and use a jumper on the two wires from the safety switch, Or get a new switch If you are unfamiliar with this.just make sure you unplug it first. If it then works with the jumper you may need to order a new safety lid switch.
Posted on Jun 19, 2009
Washing machine starts washing then stops mid cycle
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Jul 12, 2016 | Russell Hobbs RH1042 Frontload Washing...
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Washer stops mid cycle
ur drain is stoped up. the drain emptys into the sink plumbing...
Oct 17, 2013 | Admiral Washing Machines
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Hi everybody, I have a SpeedQueen Washing machine that does not complete the whole cycle while washing, it stops at the mid-cycle. What could be the cause? Thanks
It could be the heater element, if the wash water does not reach the temp selected by you within a certain time period, the w/m could abort the cycle.
The pump or outlet hoses could be blocked and the w/m cannot expel the waste water between rinses.( This would be if the machine stops and is still full of water). Try running a cold wash cycle and this should confirm if it is the element as it will complete the cycle ok.
Hope this help
Jul 08, 2010 | Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Washing Machines
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
