Question about Whirlpool WRS342FIAB 22 cu. ft. Side by Side Refrigerator with 2 Slide-Out SpillGuard Glass Shelves, 3 Adjustable Gallon Door Bins, PUR Water Filtration System, External Water Dispenser and In-Door-Ice Dispensing System: Black
Whirlpool WRS342FIAB refrigerator not getting water to door
No water is getting to the door of the refrigerator.
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Exterior Moisture
sounds like you have warm air getting into the machine, id check to make sure the doors are closing tightly around all sides with no gaps
Posted on Oct 26, 2008
I have a whirlpool refrigerator side by side with Ice & water in door. I can't get water to come out. How do I fix it?
First make sure that the water line to unit is functional. then check out the solenoid that feeds the water to the door for operation. If it is not working there will never be any water appearing at door. And if solenoid is good the switch that sends it power may be non functional.
Mar 02, 2016 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frig is very hot on the outside ban that meets the seal
That heat that you feel is part of the design of all refrigerators. Those heaters are there to keep water from condensing on the outside of the cabinet around the freezer door. Just like water condenses on a cup of Ice water. It will do the same on a refrigerator. If those small heaters were not there. The water would cause the paint to rust badly. There are various arrangements of heaters used on Freezers and refrigerators around the doors. Particularly the Freezer door.
As long as the fridge is cooling properly it is fine.
If the fridge fails to get cold, the outside of the cabinet will actually get quite hot.
Hope this helps,
Best, Mark
Dec 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a model GD5PHA whirlpool refrigerator, no ice
the ice maker control the water timing.
if you have voltmeter you can check it on the water valve that go to the ice maker. but you can also disconnect the water from the valve and see if water are coming out.
99% its the ice maker that go bad.
Jan 19, 2010 | Refrigerators
In-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water from the water dispensor not flowing anymore
Do you hear the valve opening at the back of the fridge click when you push for water?
If not ....it may need to be replaced.
If you do hear a click.....the water line may be frozen in the freezer door.
Open the door wide open for a while......1 to 2 hours and occasionally try the water.....cover the freezer compartment with towels to keep the cold in that area but not the door.
Aug 17, 2009 | Whirlpool ED5FTGX Side by Side...
Exterior Moisture
Oct 26, 2008 | Whirlpool Refrigerators
Whirlpool WRS342FIAB 22 cu. ft. Side by Side Refrigerator with 2 Slide-Out SpillGuard Glass Shelves, 3 Adjustable Gallon Door Bins, PUR Water Filtration System, External Water Dispenser and In-Door-Ice Dispensing System: Black Logo
434 people viewed this question
Top Whirlpool Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you a Whirlpool Water Dispensing and Filtration Expert? Answer questions, earn points and help others
