Question about Yamaha PRO 400 Headphones - White
Intermittent sound on one earpiece on headphones
Problem traced to socket on left earpiece. Definitely not the connecting cable
Only the left side of my Blackweb Headphones work. What's the problem?
While they may be wireless, there is a cable that runs from one side to the controller on the other side. Check this cable to make sure there are no outward signs of damage.
Mar 19, 2017 | The Audio Players & Recorders
Why no more sound in left side? the right side is fine. i moved the left side like a seesaw, then i found where the sound occur. is it the wire connection problem inside the left side? what to do?
Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
Apr 21, 2016 | SOL Republic Master Tracks MFI...
Left earpiece intermittent.
The electronic components are defective. It is not worth repairing unless you paid a lot of money for the head phones.
Dec 05, 2015 | Maxell HP/NC-II Noise Canceling Headphone
No sound in left headphone
Yes, sure. But it's a bit difficult, because you have to find the broken piece of it. Look for cuts in the wire. If you can see it, you can cut the protecting piece over the wire open or off and connect your wires again. Melt them together and it should work.
Jan 02, 2014 | Wesc Bongo Headphones
The sound is only coming through one of the earpieces, usually the right one. When I move the headphone cable connecting to my laptop to the left or right, it switches to that headpiece. I don't know why...
It sounds like a short in either the wire or the connection to the computer. 90% of the time this is caused by the cable getting pinched somehow, or just getting old. You'll need a new wire, so probably new headphones altogether.
Sep 12, 2013 | TDK Audio Players & Recorders
Left ear bud lost all sound- no cord damage-only 5 months old...is it worth getting fixed by professional or is there something I can do to fix it ? H
The cords are sealed into the earphone. You can take a multimeter and test the continutity of the either earpieces, once you are convinced that the left side is faulty, first of all use a small thin needle as the probe, use your multimeter in the continuity range, holding one end of the meter probe to the jack , inset the pin like an ijection into the wires to obtain the connection, it there is no connection out of the headphone jack, I think you can replace with a new one to be soldered. If not proceed to the earpiece to confirm, then open the sealed unit and be lucky if the earpiece is not damaged but only the wires. Good Day
Jul 07, 2010 | AKG K 321 cloud white Headphones
Left earpiece has no sound.. can that be fixed?
either theirs something that happaned to the wire like it got stretched out and the inside braided wires pulled apart or came disconnected from the piezoelectric elements, or you have blown the side out.
Dec 21, 2009 | Bose in-ear headphones - Black with...
The left side seems to have a faulty connection with the sound being absent or intermittent. Occasionally it sounds normal. Waggling or tapping the actual ear phone seems to activate the sound but dfficult...
You might have a bad connection on the wiring terminal inside the left speaker where the left and right join the main cable. Here is a link:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Nov 25, 2009 | Bose On-Ear Headphones
If I jiggle the cord in the stereo outliet, the sound switches from left to right earpiece and has to be just right in the outlet to get both earpieces working at the same time.
If you plug the headphones into another device do they stay on solid?
The problem can be the cord/plug (headphones) or the socket which your plugging into. Socket might need re-soldered or replaced.
Jul 26, 2009 | Bose QuietComfort 3 Acoustic Noise...
Yamaha PRO 400 Headphones - White Logo
43 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
