Tascam Cd-X1500 dual cd player ERROR MESSAGE
My right hand deck is giving me the error message err 02 or err 03 when inputting a disk. Tascam's manual suggests to try a new disk/ clean present disk. I have tried many times with many differnt cds with no luck. The next port of call would be to take the unit to a service centre, i was just wondering could this be solved an easier way eg disk cleaner? I don't want a hefty repair bill but if this is the only option then sadly i'll have to take it. Can anyone help??
  • 1 more comment
  • dronai Jan 28, 2008
    I have the same problem with my tascam
  • Anonymous Mar 02, 2008
    I have the same problem with my Tascam CD-X1500.  The left side plays the CD fine but the Right side displays an Error 03.   I'm tried different CD's with the same results.
  • Anonymous Nov 07, 2008
    i have the same problem but its my left hand player not my right one help me please ddykstra@westlockinn.com thanks
  • 93 Answers
SOURCE: teac sd2000
It SHOULD work.
Posted on Oct 04, 2007
jerryg50
  • 1689 Answers
SOURCE: denon udcm m7 cd player often reads ERR on play and eject
Try cleaning the laser first. Take care, because it is delicate.
Some instructions of how to clean a CD laser:
http://www.wikihow.com/Clean-a-CD-Player
If the cleaning does not fix the fault, it is possible that the laser is weak, or there are some problems in the electronics in the CD player. This is not something you will be able to service yourself, unless you are properly trained, have experience, and have the proper setup to perform CD player servicing.
In most cases these CD players are not cost effective to service. You can contact the orignal manufacture for details or any recomendations.
Jerry G.
Posted on Apr 29, 2008
  • 3422 Answers
SOURCE: Tascam CD A500 'No Disc' error message
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on May 01, 2008
SOURCE: Tascam CD-A500 'no disk' problem
How hard is it to replace optical lens on the Tascam CD-A500?
Posted on Oct 14, 2008
SOURCE: Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
Posted on Jan 08, 2011
Shows err- 3 on power up.
I think it is refering to an external control device such as a wired remote. You might try unhooking external connections and then re-hooking them and then booting it back up. Good Luck
Sep 02, 2014 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Shows err 3 on power up.
It could be belts or internal cam motor contact sensors. The transports that Teac sells are not direct replacements and DO NOT WORK.
2007 Honda Accord SE CD error
Just go to a auto wrecker end get a different deck for it, It will cost you less then to have it repaired,
Dec 03, 2012 | Audio Players & Recorders
My tascam cd-1500 dj left side only display good day while the right side is fine
how can i b deck going on my tascam x1700 from gd day when i got deck a working i cant remmber what i pressed can any one help
Aug 25, 2011 | Tascam Cdx1500 Dual CD Player CD Player
The left hand deck has difficulty playing CDR discs.
the lens wants to be clean.if that does not correct the problem.the lens needs to be replace.good luck.
Feb 28, 2010 | Tascam CD-302 Version 4.0 Dual Deck CD...
Need cords
8-pin mini din cables p/n: 9109030600, you can buy them from any authorized TASCAM/TEAC dealer.
Jan 11, 2010 | Tascam CD-302 Version 4.0 Dual Deck CD...
TASCAM CD-01U err code
Get a pick up.. Look on line for a pick up for the unit. This is a common problem for these units
Jul 08, 2009 | Tascam CD-01U CD Player
Panasonic CQ-DF903U CD Player
When you unhooked your deck it still had power going to it, you need to unplug your car battery and plug it back in that should reset the deck and get the error message to go away.
Good luck,
Chris
Feb 27, 2008 | Panasonic CQ-DF903U CD Player
Califone 2385AV-02
PUT AN CLEANER DISK INSIDE(DISK WHICH CLEAN OPTICAL PATH INSIDE)-YOU CAN OBTAIN IT FROM NEAR RADIO SHACK.
PUT AN GOOD CD AND TEST.
Jan 04, 2008 | Califone International (2385AV-02 ) Single...
297 people viewed this question
 Grubhead
Grubhead
