Question about Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18
What are the blue and red wires in utilitch pro led light
Hey, i own a husqvarna sm610 and im trying to remove the stock tail light and blinkers and install a new LED tail tidy strip.
Keep things simple and make this much easier. You will need a test light and probe each of the wires and you will have to do each wire while the lights are on, then the brake applied and then the turn signal and you will be in business in short order. Be shure to make all connections secure and use shrink tubing to waterproof the wires.
Mar 18, 2014 | Cars & Trucks
Which wires connect to my aftermarket brake-tail light
Hi Anonymous,
Black=Ground
Red=Brake Light
White=?
Blue=Tail Light
Good luck
Jun 16, 2013 | 2000 Harley Davidson FLHR-FLHRI Road king
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
What colors are the wires for the pwr sw, smi,rst,hdd led,grn led and where so i plug them in at s7sen 15-a01-013010 rev 3.0a
- the colors of the wires (can differ, depends on the case type):
  • Green(+ is the colored wire)-White(-) --> POWER LED (GREEN light)
  • Red-Black -> POWER SWITCH
  • Red-White -> HDD LED (RED light)
  • Blue-White -> RESET
  • Red-Black (4 pins wide)-> SPEAKER
Sep 03, 2010 | EliteGroup K7SEM Motherboard
Connect power swithc and led cables to foxconn n15235
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
http://www.foxconnchannel.com/en-us/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Mike
Nov 10, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Broken Sensor Sterling Touch Immobiliser
There are 4 wires going to the touch pad unit which has an LED in it. The unit has 4 pins (or legs) to which the wires must be soldered. As you say, there are two blue wires plus a red and also a black - although as you also correctly observe, only three wires are present (blue, red and black) in the connector at the other end of the loom which plugs into the control module.
The blue simply splits two ways within the loom, and these are earths. The black carries a pulsing voltage to drive the LED, and the red (which should measure a constant 5v on a voltmeter) is an input which senses when a key is touched on the pad.
Use a continuity tester or ohmmeter to establish which of the four pins on the touch unit connects to the CENTRE pin of the touchpad. Solder the RED wire to this pin. (Best to start by putting some heat shrink up the wire as the pins on the touch unit are quite close together and there's not much to stop them touching.)
Again using the continuity tester (or ohmmeter) establish which of the remaining three pins goes to the OUTER ring of the touchpad. To this, solder one of the BLUE wires - it doesn't matter which one. You must however get the wires to the touchpad the correct way around in order for the key to be read.
You're now left with one BLACK and one BLUE wire which drive the LED, and two pins on the unit which have no connections. The LED will only light when you get these the correct way around. You will not do no harm if you connect them the wrong way round - the LED will simply remain unlit.
One you have soldered the BLUE and the BLACK wires in place so the LED is flashing, simply test your work by touching a key on the touchpad. If all is well, the LED will light continuously for a period and it should be possible to start the car.
Sep 24, 2009 | Vehicle Parts & Accessories
Blue LED light connection from Bezel to Motherboard
red white is the pair that supplies power it should be 2pin socket on motherboard
Sep 19, 2009 | E-Machines T6520 PC Desktop
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18 Logo
123 people viewed this question
Top Utilitech Pro Home Security Experts
Lawrence Oravetz
Are you an Utilitech Pro Home Security Expert? Answer questions, earn points and help others
