Question about Philips 55PFL5706/F7 - 55 LCD HDTV with Wireless Internet
Factory reset philips 55pfl6188s/12 - Philips 55PFL5706/F7 - 55 LCD HDTV with Wireless Internet
Hi, my Philips TV 46PFL3608/f7 ds1 turns on, shows philips logo and turns off. I need advice what I should change. PSU, mainboard or somethink else ?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 06, 2016 | Philips Televison & Video
Not possible to select screen modes but Philips logo comes permanently.
Corrupted firmware. A firmware update is necessary. Contact any service technician; or the authorized service center for Philips. It is a skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Before doing anything, try a hard reset to this set, and check.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.
May 22, 2015 | Philips Televison & Video
I have a Philips tv model 32pack4507. It was working but I can't get it back on either manually or with a remote. Do I need part or new tv
Check batteries in remote. Or possibly a new universal remote. I just purchaced a RCA universal remote. Works better than the original factory remote, and easy to program to the correct code.
Apr 14, 2015 | Philips Televison & Video
How to return philips 40pfl7705d to factory settings
I don't think it has a factory reset but Philips would know if they or a authorized service center will talk to you----both are generally not very helpful.
Dec 03, 2012 | Philips 40PFL7705D 40 in LCD TV
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
I have new Philips LCD 47"tv and on the bottom
HI:
You may of turned on the Philips Easylink which is for connecting Easylink-compliant devices that are connected through HDMI connectors can be controlled by a single remote.
You can restore the default picture and sound settings of your TV.
1. Press MENU
2. Select SETUP> Installation>Then Factory settings.
3. Select Reset to start resetting
5. Press OK.
6. Press MENU to exit.
Jan 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
Our philips lcd tv picture turns off but sound stays on and then the piture won't come back on for longer while.
Suddenly, the sound for LCD 42PFL3605/12 dissapeared. Resetted to factory settings, upgraded firmware, but no result. The TV ran just 24 hours. Please, help!
Dec 19, 2010 | Philips 47PFL7403D 47 in. LCD TV
My PHILIPS 34PT9420 tunes only fifty channels and not more than that.Earlier it use to tune 99 channels.So kindly tell me how to tune all 99 channels or how i may have changed some of its factory settings...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Aug 23, 2017 | Philips 34PW8502 34" TV
Philips DVD622 Factory reset
Go to http://www.philips.com and search for your modal then look in Q/A's or just look in the manual for the factory reset....Usually found in the on-screen menu!
Jan 10, 2008 | Philips DVD622 DVD Player
Philips 55PFL5706/F7 - 55 LCD HDTV with Wireless Internet Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
