Question about Kenmore Refrigerators
Kenmore 106.70182000 thermostat testing
Compressor works, freezer fan works, ambient temp 60, evaporator frosted at beginning. No cooling.
  • 306 Answers
SOURCE: ge side by side tpx24biyaww freezer not cold enough.
You have to find out why the compressor shuts down at 28 degress rather than going on to zero?
You probably need a voltmeter to see what shuts down at 28. The thermostat may be faulty.
What is stopping the compressor from continued opertion until zero freezer degrees is reached?
Go figger!
Posted on May 01, 2009
Healeyman
  • 1198 Answers
SOURCE: Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
Posted on May 03, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
  • 884 Answers
SOURCE: WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator.
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Posted on Apr 28, 2012
pw_168
SOURCE: LG express cool no frost
Just defrost the fridge. Once defrosted, the food compartment below the freezer should cool.
Posted on Feb 10, 2013
I have a Kenmore Elite model no is 59673502201 and it stop cooling in both the frig and freezer i replaced the condenser fan motor and it worked so i replaced the back and the unit will STILL NOT GET
Do you hear your evaporator fan running in the freezer drawer area?
If not, then that's the fan you should have replaced.
If your compressor is running and both the compressor fan and the evaporator fan are running, check the back wall of your freezer compartment. If it is frosted up, then you have a defrost problem.
If it's not frosting up, disassemble your freezer drawer section and remove the back panel in the freezer to look at your evaporator coil.
If it's partially frosted at the top, or bottom, but the rest of it is dry looking, then you've got a leaking sealed system.
If it's lightly frosted all over, then you have good coolant flow and you need to start looking at your thermostat and damper up in the fresh foods section.
Nov 10, 2014 | Kenmore Refrigerators
Fridge not getting cold
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 31, 2013 | Refrigerators
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Apr 27, 2012 | Refrigerators
Kenmore elite fridge top is not cooling
Oct 18, 2011 | Kenmore 53632 / 53634 Side by Side...
Fridge not cooling .kenmore trio frezer works fine
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Oct 06, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore refrigerator Model 253-68232800 will not keep food cold in fridge and frost build up in freezer.
Top of Form
Sep 14, 2011 | Kenmore 64722 Top Freezer Refrigerator
Freezer & fridge have stopped working. The fan was running but the temp on the fridge was 93 and climbing.
Thank you for using Fixya.
Sep 05, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
KENMORE REFRIGATOR FREEZER THE FREEZER WORKS FINE THE REFRIGATOR IS WARM
Jul 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
My kenmore elite model 596.73509201 just stoped cooling things, i did take the cover off bottom and vacume off the coils, they were very dusty and pulled it out to clean behind, but with nothing in it...
Hello. First thing you want to do is listen to see if you can hear the compressor running. It is the round tank in the back. this holds and pumps all the freon through your unit. If it is not humming, then it will not cool. This is probably the most expensive part. Around $250-$400
If compressor is running, then you will want to look in the evaporator tray attached to top of compressor. It should have some water in it. If not, check that the drain tube above it is not blocked. If so, unclog it.
If all this is working fine, then your problem is in the temperature control unit. Either temp control itself, or the temperature sensor which is located inside the and above freezer panel.
Last possible cause would be the control board which also runs to the compressor and can automatically shut the compressor off it it reaches a certain temperature.
The best bet is to get manual and any parts at www.repairclinic.com
Oct 08, 2009 | Kenmore Refrigerators
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
