Question about Danby Dishwashers
Danby ddw1899bls control panel not working
The dishwasher on button must remain manually depressed for a cycle to begin. As soon as the button is released the dishwasher shuts off.
COXY
  • 76 Answers
SOURCE: Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Posted on Nov 18, 2007
SOURCE: My dishwasher control panel does not light-up
This is a common problem. I am about to replace my second control panel in two years. First time was under warranty and I hope this time will also e under warranty.
Posted on Apr 25, 2008
SOURCE: Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Posted on Aug 19, 2008
SOURCE: Danby dishwasher E3 error
Same issue here so I just got off the phone with Danby. They said the E3 means the water is not hot enough when it goes into the machine. Now I dont know your guys situation but I let the water run hot until I cant touch it anymore, then I turn on the machine and plug it in. So it sounds like the heating mechanism is not working properly and does not heat the water to the appropriate temp to continue with the cycle. I will say that their support was really friendly and she informed me that since it was purchased less than a year ago it would be covered under the warranty. She gave me the number of a local repair shop. Lets just hope they dont tell me nothing is wrong with it because my water temp is fine. I will let ya guys know. Here is the number for Danby that I called. General office: 419-425-5052. Good Luck!
Posted on Feb 13, 2009
  • 132 Answers
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
Won't turn on and stay on unless you depress and hold the start button...
Have you recently smelt a burning smell? We did, the power switch had shorted/was faulty (we stuck some toothpicks in which helped jam it in for a bit, until it failed completely). You need to replace the power switch, PN 674000300089
There is an excellent video which explains how to replace this (also has a link to buy the part), we did it ourself just for the cost of the part.
https://www.youtube.com/watch?v=BwkPGDIxC6s
Mar 13, 2016 | Danby Dishwashers
Soap dispenser door doesn't open during washing
make sure top rack is not jammed with dishes and is pushed in all the way.
Feb 10, 2014 | Danby DDW1899BLS Builtin Dishwasher
Power switch replacement
There is a video yuou can watch which details this exact repair:https://www.youtube.com/watch?v=BwkPGDIxC6s
Jan 03, 2014 | Danby DDW1899BLS Builtin Dishwasher
DDW1899BLS fuse location
There is a video that demonstrates the proper and safe way to disassemble a Danby DDW189BLS dishwasher and how to access parts that may need to be tested and/or replaced.
https://www.youtube.com/watch?v=CoGi6bzRN1g
Dec 03, 2011 | Danby DDW1899BLS Builtin Dishwasher
Is it true that it takes about 2 1/2 hours to go through a normal cycle? If not, how long does it take, approximately? I am asking about the 18 inch built-in.
I cannot find any mention of times for this particular machines run, I have found the Users Manual HERE. I don't think it should take 2 1/2 hours to run this unit through a cycle, perhaps 30 minutes to one hour.
I hope this answers your query.
Joe
Sep 20, 2011 | Danby DDW1899BLS Builtin Dishwasher
Where can I find a mnaual that can tell me how to de-lime a Hobart CRS66A Dishwasher?
I doubt that the user manual covers de-liming the Hobart Dishwasher.   If I owned this (fine, expensive) dishwasher, this is what I would do.
1.) Discard any generic, ultra-cheap detergent.  Stop using gels or tablets and only use powders.  Buy a box of brand name powder (like Electrosol or Cascade)  You will be amazed how much difference that will make because the newest generics have mineral bulk added that build up faster then hard water does on both the stainless steel enclosure plus the silverware and even plates.  White patches.  I LOVE generic products and saving money, but low end dishwasher powder is one place I no longer choose a generic product.
2.) Add two cups of white vinegar to the empty dishwasher and leave it there until the morning.  Run a quick cycle with no detergent added.  The vinegar will be pumped out immediately after you begin this quick cycle.
3.) As soon as the dishwasher fills with water during that quick cycle and begins a wash cycle, add two cups of white vinegar and close the door and allow to run the full wash cycle.
4.) When the dishwasher finishes the drain cycle and begins to fill again, open the dishwasher and check the enclosure for remaining "lime" deposits.  If they remain, keep adding 2 cups white vinegar each time the dishwasher refills and begins to wash/rinse again.
You should be delighted with the results. Long term, you should consider adding a whole house water softener and then reduce the amount of dishwasher (and laundry) detergent by one half.  Amazing increase in quality of life by adding a water softener.  You will be delighted.
Please post back with you results, OK?  Good Luck!
Apr 17, 2009 | Dishwashers
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
