Question about iHome iHM59 Rechargeable Color Changing Mini Speaker
Ihm59 stopped working
No sound but still lights up
My Vivo ptv42hda tv makes a clicking sound when switched on but screen won't turn on how can I please fix the problem myself thanks as I'm good with electronics
do you have back light or not? and do you have sound or not?
if back light comes on and sound on but still no picture.. problem is in T-Con PCB.
if no back light.. but sound ok.. problem in back light.
Jun 02, 2013 | Televison & Video
Overload light on can't get any sound
here is your guide:
http://www.fixya.com/support/t13907270-sony_str_de925_stuck_in_protect_mode
Note : output transistors are embedded inside the Hybrid IC
on some models.
Aug 07, 2012 | Technics Audio Players & Recorders
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Alarm sounds when you open the drivers door...
Most likely a bad ground switch in the head light switch.
Jan 24, 2010 | 2002 Chrysler PT Cruiser
The audio light is red whether the sound is muted or not
1) Try updating your sound drivers, they probably control the light. It could be a hardware issue, and if the drivers don't work, there may not be any solution for you.
2) You should go into control panel and into your sound settings. There should be a number of devices listed. One of them is your HDMI output. You need to click on it and set it to the default sound output device. When you unplug your HDMI, you may need to do this again to get your regular computer speakers working.
Jun 22, 2009 | HP Pavilion dv7-1130us laptop
My system is not showing any error message or post message in monitor.
beeping sounds, light flasing when you turm on machine, machine will not even turn on, mute sounds how many and long or short sounds or mix sounds, same witrh lights short or long light signals.
or more information than you are giving me
rod
Feb 01, 2009 | Computers & Internet
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
iHome iHM59 Rechargeable Color Changing Mini Speaker Logo
203 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
