Question about Apple Power Mac G5 Desktop
Same issue exactly the same problem tried to clean it up, used 20 different medias if you retry dozen times at the end it will burn .. or not
    Problem Solver:
  • 6 Answers
Are you talking about try to burn A DVD... what are you turn to do?
Posted on Jun 21, 2009
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
I keep having failed burn sessions it says "Power Calibration error" what and how can I fix that
Their could be several possible reasons and solutions for the above error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
Try burning at lower speeds (Highly effective).
If this fails try a different burning software
Aug 20, 2010 | Sony AD-7191A DVD±RW Dual Layer Burner
I bought my Phillips CDR560 about 4 years ago and probably used it no more than a dozen times. For the past couple of years it has been in the loft unused. I tried to use it the other day and I kept...
OPC (Optical Power Calibration) errors are related to the drive trying to test how strong to make the burning laser. If you recieve this error, the piece of media you are using may have problems. Try different blank media.
Aug 08, 2010 | Audio Players & Recorders
Using Premiere Elements I've burned a couple of different videos onto DVD's to run on my TV. they have hiccups in the audio at just about the same place. could this be 1) the burn process 2) my dvd player...
Its not the fault of your media, or ur dvd player. It is the matter of the burning process so don't bother about ur media or player. try to burn not exact the same amount of stuffs as exact as space in DVD. pls leave some space for ur writer so that it can place the supporting stuffs to burn ur stuffs properly.
Jun 16, 2009 | Dell Studio 17 Laptop
Dvr-k16d dvdrw can't burn cds
if u get this error in every cd try different brands of media if it remains the same then try different burning softwares if problem persists then pls try the cleaning procedure for lens as follows
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works
pls do rate me FIXYA for help or ask more help if u want
Mar 31, 2009 | Computers & Internet
Hi I have an LG DVD±RW, it used to work properly but few days ago i tried to burn an iso. image it didn't work Device: [1:0:0] HL-DT-ST-DVD-RAM GSA-H55N 1.02(E:) (ATA) Firmware Version: 1.02...
According to the log file, there was a spindle servo failure. The spindle servo is responsible for maintaining rotational speed accuracy. I'd say your drive is pretty much dead. See if you can read a disk in the drive. I wouldn't be surprised if it had a tough time just reading files.
Jan 23, 2009 | NEC ND-3500A DVD±RW Dual Layer Burner
Mysterious "ring" on burned DVD causes playback to freeze.
Is the image preponderantly encoded in PAL? Majority PAL and some NTSC? Or fully NTSC? Used transcoding presets? Transcoded project before you built to DVD? Note: Always run "TEST" before burning (to save plastic trees)? Determined whether system or project is faulty? Tested the DVD drive? Tried burning using another application? Closed all background-running resource hogs and applications? Did the project size increase the capacity size of the disk? Used a lower write speed? Disabled startup items and services? DMA: enabled? Updated Windows? Media compatibility? System requirements attained? Updated your application? Solved the issue(s); then write it down and share it with others. Still having issues? Revert back to the computer's factory settings and rebuild, upgrade, or invest in a high-end system and buy the full version of Nero 9, with all the plug-in features....and so forth. If time is money, the latter solution is your best bet. If money is an issue, then it requires trench warfare - that is, much research, deductive reasoning and time investment to isolate your specific problem...start by analyzing your source, and then your target...cause/effect relationship...you'll conquer all problems, eventually...political machinations aside. Ye all be happy computing Chomskyites. Dr. Frank Kohnstein.
Oct 29, 2008 | JVC DRM10 DVD Recorder
Old Tapes work new ones don't
I'm having this exact same issue and according to the DELL tech it is common. What I had to do is keep using the tapes until they started passing. I bought 2 brand new cleaning tapes and ran two cleaning jobs before it would pass. My daily tapes are passing, and after several retrys my weekly tapes are passing. Since my Monthly tapes occur so infrequently, I'm just taking one of the Daily tapes out of the rotation and using a Monthly tape until it passes. It's either this or buy a new tape drive.
Oct 28, 2008 | HP DLTVS80 (C750760008) Tape Drive
CD/DVD Combo Drive Just Not Burning DVD
I had problems with tsstcorp in my drive. The software you are using won't work. You need to try sonic or roxio. I had the same problem. Do you have a dell? if so download the updates from the support website. Try a different software because a reinstall of xp should get rid of bugs in system. It sounds like a software issue though.
Apr 14, 2008 | Computers & Internet
Apple Power Mac G5 Desktop Logo
59 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
