Question about Asrock G41MVS3 Motherboard
MOTHERBOARD NO POWER
I'm using Asrock G41MVS3 Motherboard R2.0 and suddenly the power turns off when i plugged the video card on it while it's open. What should I supposed to do? It doesn't turn on now.. I already checked the PSU, power button and wire of button and they were all working.
sandrew
  • 2961 Answers
SOURCE: Onboard sound doesn't work
click search, then type dxdiag, click the sound tab and a diagnostic programme will check your sound driver and report any faults
Posted on Sep 26, 2007
  • 24 Answers
SOURCE: cannot turn on motherboard
Either the power button itself is bad, or the mainboard is bad. You can test the power supply and mainboard by using a paperclip to short the green wire on the middle of the power connector that goes to the motherboard to the black wire next to it on the same connector. This will force the power supply on. If the mainboard still won't do anything, then it's dead, Jim.
Hope this helps!
Posted on Jan 31, 2008
map9966
  • 2351 Answers
SOURCE: ASrock P4i45GV Motherboard
Hi sandesh8, did you know you can increase the memory size of the onboard AGP card above the 64MB? Page 26 in you're manual. If you install another AGP card into the opened AGP slot, please go to this site & only use the recomended AGP cards in the Asrock list. Click on this link: http://www.asrock.com/mb/vga.asp?Model=P4i45GV%20R5.0&s=478&c=VGA
This is one of very few video cards found on the list with 256MB of video memory.
http://www.amazon.com/nVidia-GeForce-FX-5700-5187-6725/dp/B000RPKI28
Good Luck!
Mike
Posted on Jun 08, 2008
syedmujahed
  • 158 Answers
SOURCE: CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Posted on Sep 27, 2008
beast_b9
  • 113 Answers
SOURCE: no pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
Posted on May 02, 2009
Ethernet not working
What version of windows are you using ?
Are you using drivers from the Asrock website?
Apr 24, 2014 | Asrock G41MVS3 Motherboard
Memory power beep
check ram slots. one at the time.
1ram--boot 2ram--boot and so on
Oct 12, 2013 | Asrock G41MVS3 Motherboard
No VGA output
Hello the drivers site is here:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=G41M-VS3
The manual:
http://www.asrock.com/mb/overview.asp?cat=Manual&Model=G41M-VS3
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Nov 28, 2012 | Asrock G41MVS3 Motherboard
Hi Guys, I have Asrock 775VM8 mother board, and want to upgrade the graphic card to ATI 9600 Pro (256 MB). I just wonder if this motherboard can support that card at all. The motherboard clearly says...
Since your motherboard is responsible for the supplying power to your card there is no harm in mounting the video card. As far as i know if the voltage capacity of the video card is lesser than the voltage supply of your board then you should not try it. AGP gets its supply from motherboard so do with PCI slot. You will notice the performance of the video if the supplied power from your board is not sufficient.:D
Mar 15, 2011 | Asrock 775VM800 Motherboard
What video cards are compatible with my motherboard i have a 7100 GS palit video card, will it work?
Palit Geforce 7100GS video card has a PCI express interface, which is the standard nowadays. Your ASROCK motherboard has a 4x/8x AGP interface. That video card will not plug into your motherboard. You can use any video card that has an 8x (or 4x) AGP connector, or just use the built-in video that is already on the motherboard.
Nov 29, 2010 | Asrock 775VM800 Motherboard
Asrock motherboard prescott 800
If your monitor is plugged into your computer in the same area as your USB ports and everything else, you are using on-board video. If it is plugged into a card using one of the expansion slots located lower on the computer, it is a separate video adapter. Changes to BIOS settings can make it so it is not sending your video output ro the correct port in that case. You could have a problem with your power supply or your motherboard. Just because you hear the motors on the devices doesn't mean there isn't a power porblem. The motors use 12V DC, but most of the logic circuitry that makes everything else work is only 5V DC. Many motherboards have a small LED on them that serves as a "power good" indicator. If that is not on, the power supply is the most likely culprit, otherwise the motherboard probably needs to be replaced. Something else you should check before buying replacement parts is that no USB flash devices are plugged into the computer and that no blank CDs are inserted into any optical drives. I have seen both cause similar problems on other system.
Jun 07, 2009 | Asrock P4i65G Motherboard
My video connection does not work monitor says "no signal." I checked all connetions and they's properly connected.
Check to make sure you have correct ram installed in motherboard as the video card may share that ram. Check CPU that it's installed correctly and video should work. If not then the motherboard is bad.
Jun 01, 2009 | Asrock P4I45GV R5 Motherboard
Pci video card
If you have internal graphics, you need to enter the BIOS and change the vide setting to PCI-E, AGP,Etc.., save and exit the BioS, power off PC, then install video card, make sure all needed power connectors on vide caard are plugged in (some nes cards require a plug from the power supply to be used as well as the power provided from the PCI-E slot)
gomez73
Mar 26, 2009 | Asrock K7S41GX Motherboard
Good Luck!
Mike
Jun 08, 2008 | Asrock P4I45GV R5 Motherboard
Asrock G41MVS3 Motherboard Logo
56 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
