Question about Samsung G2 Portable External HX-MU064DC/ GB2 640 GB USB 2.0 Hard Drive
Hardware changes might not have been detected
The hard drive was working and has recently stopped working. It is detected in the devices but cannot be opened. I have tried going through the device manager - uninstalling it, rebooting the computer and then reinstalling it but I get the error message "Hardware changes might not have been detected." It also shows up on the toolbar to eject safely but again I can't open it. I've also tried it in the two other usb ports on the computer as well as trying it in two other computers. All result in the same issue. Please can you help?
  • 32 Answers
SOURCE: Can't read the content
What's happening is that there's no windows formatting on the hard drive as it is part of your Video Recorder. So the only other option that I'm aware of (although I'm sure there a thousands of other options) is to download Slax Linux Boot CD (follow the link below) and boot into Linux. Linux is able to read drives in RAW format and doesn't need all the formatting stuff that windows needs. Then you should be able to copy the desired files from the hard drive onto whatever drive you want on your PC. Let me know how this goes.
http://www.slax.org/get_slax.php?download=iso
Posted on May 01, 2009
  • 101 Answers
SOURCE: problem in hard disk
control panel
computer management
disk management
select the disk and iniatlize by right clicking.
Posted on Jul 09, 2009
kamal1984
  • 1383 Answers
SOURCE: HDD enclosure does not work
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Posted on Aug 01, 2009
bob_computer
  • 3153 Answers
SOURCE: I did an ASR recovery after my harddisk got wasted
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
It is also possible that if the port you are using gets a lot of frequent use than it may need a little TLC with a fine tipped soldering iron.
Quick checks of the drive itself can be done by removing it from its enclosure and connecting it directly to a comuter that has the correct interface. If you can read and use the drive then you know it is not that.
If you cannot use the drive in any way and esp. if you hear clicking or pinging then the drive is almost certainly dead or dying.
Posted on Aug 26, 2009
prerit_777
  • 214 Answers
SOURCE: My SAMSUNG HM080HC
reinstall its driver
Posted on Aug 02, 2010
My hp g62 wouldnt detect hard drive and now its saying no boot disk on black screen
Remove hard drive and reseat back into place, sometimes works, if no change, it is more than likely the hardware is bad and will need to be replaced.
Mar 07, 2012 | HEWLETT-PACKARD HP G62 Notebook
The message on my computer says: "A problem has
This could be a problem with your hard drive.
Before taking it to a shop, please make sure you have NOTHING at all plugged in that wouldn't normally be there.
No USB devices (except KB and Mouse) - No memory cards - No external Hard Drive etc.....
All the above devices can be bootable.
Apr 26, 2011 | Toshiba Satellite® P105-S6084 PC Notebook
My External Hard Drive isn't working anymore, to say the just of it. It's on, lights on(not flashing, it flashes when it's being written to or accessed), usually has a regular clicking noise from it...
When a hard drive makes a clicking noise, this indicates the hard drive has failed and if the BIOS and the Computer Management does not detect it, then this confirm a hard disk failure.
To get the computer operating again, replace the hard disk, then install Windows on the hard disk using the Windows installation CD and the Windows product installation code that is on the label on the computer then install the device drivers and your programs.
Oct 21, 2010 | Samsung Computers & Internet
Been working fine in winxp pro for 2 years - suddenly fails to show & in Device Manager Other shows TUSB6250 Boot Device but can't find driver
Is there any recent changes on the computer?
have you tried to disconnect and reconnect its cable?
Sometimes we just need to reseat the cable for the HDD to be detected.
Feb 22, 2010 | LaCie Big Disk 500 GB Hard Drive
Start up problem
Restart the Laptop and press F8 you will get a option that sayd repair my computer select the option,
If repair mu Computer doesn't work than go to BIOS and check if the Hard drive is detected in BIOS or not and than perform Hard drive test in BIOS there is utility which will allow to perform the test of hardwares.
If Hard drive is detected in BIOS nad Hard drive test passedthan you need to reinstall the windows.
If Hard drive test failed or it is not reflected in Windows than replaced the hard drive and install OS on new hard drive.
Thanks and Regards
Jul 05, 2009 | Compaq Presario 700 470024-192 Notebook
Disc drivers not working
hi dorys_brian,
you may go to your device manager first, right click on the first item (saying: computer) then click on the option that says "detect hardware changes". once this is done and you are online, your computer will ask for drivers which can be found in the internet. this is strongly effective for vista. but please note that if you change OS from XP to Vista, some hardware that worked for xp may not run on vista because of drivers not made for the said hardware to work on vista.
hope this helps, lemme know if you need more info.
regards,
voodoo
Apr 14, 2009 | Computers & Internet
My laptop doesn't detect the external hard drive
Hi there
hey if you are not getting it to recognizing the drive on system startup use your set up disk if you have it if not go to device manager and scan for hardware change and see if it can be found there if not try going into the bios and ensure that the usb ports are enabled and that the plug and play is enabled also you also need to ensure that the device is compatable with your pc i would check with the manufacture of the computer best regards mike
Dec 13, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
None of my external hard drives or flash drives recognized by Vista
Ok Go into your hardware device manager and uninstall your Universal Serial Bus Controllers and if there is mass storage device also uninstall it. Click on action -> scan for hardware changes, then it should automatically install the drivers back now it should detect.
May 03, 2008 | Maxtor Hard Drive
Samsung G2 Portable External HX-MU064DC/ GB2 640 GB USB 2.0 Hard Drive Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
