Question about Cuisinart CBK-200 Bread Maker
My bread machine was working fine, but when I took it out to use again later the same day there was no power, nothing happened at all. I tried other outlets, no go. The cord seems fine.
3 Suggested Answers
SOURCE: bread making
I had the same problem with a loaf of whole wheat bread. I also am a new bread machine user and followed directions explicitly. What I figured out was that the pan was not seated all the way into the clips so the paddle mechanism wasn't connected to the motor.
Posted on Mar 20, 2008
breadwizard
  • 132 Answers
SOURCE: I have a convection bread maker. I made one loaf
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Posted on Jun 25, 2011
2008 Chevy Equinox would not start, turn key and nothing happened, replaced battery, ran just fine for a week. Tried to start one week later it acted like it wanted to start but wouldn't. Had ju
Usually a sign of something draining the battery.
The machine test probably showed the battery could hold a charge and the alternator was charging the battery.
You may need to have someone check for a power drain.
When the key switch is off, there may be a weak short to ground or a relay or component that is using power.
Jan 22, 2013 | 2008 Chevrolet Equinox
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
My bread maker had a burning smell, i thought it was some of the flour i had spilled outside that burned, but now its not working at all. No buttons are working only some kind of digital hour. Stpped...
I had the same problem. Made a terrible smell and none of the buttons worked. This happened after I had hit the stop button during a dough kneading cycle and then tried to run it again from the beginning. I just gave up & put the machine away. Now 2 weeks later, I have pulled out the machine and turned it on and it is working perfectly! (It's an Oster). In the meanwhile, I found a lot of useful information at the following site: http://www.breadmachinedigest.com/tips/bread-machine-maintenance.php
Oct 08, 2010 | Kitchen Appliances - Others
One day when turning my tv on it made a high squelling noise and would not let me shut it off. I had to unplug it. I took it for repair and after 2 weeks they said nothing was wrong with it. Two weeks...
AC spikes from your ac outlet causing a temporary overload condition in the power supply circuit. This is why you couldn't turn it off, you may want to get a digital surge protector.
Jun 13, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Dodge ram van e250 dies while driving
try changing the coil- sometimes they get hot and break down- once they cool off vehicle will start and run until they get hot again
Jul 05, 2008 | 1992 Dodge Ram 250
Samsung L730 Lense Stuck Open...
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
May 11, 2008 | Samsung Digimax L730 Digital Camera
Power
I had the same problem with a tr2500bc.
I took it apart and found a bad soldier joint reapaired it and it is ok now.
Feb 13, 2008 | Breadman TR2200C Ultimate Bread Maker
Random no audio
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Cuisinart CBK-200 Bread Maker Logo
69 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
