Question about HP LaserJet 4 plus Printer
The paper jamed now I get a 41.3 error message and can't solve
Hp4 laserjet started to pring, jammed. I pulled the page out and another page came up the same way. keep getting a 41.3 error message and cannot open the paper tray or find any other jam..
  • HP Master
  • 1,684 Answers
The error 41.3 is unexpected paper length and was caused by the printer pulling more than one sheet. Now the problem is clearing the paper jam in the paper tray. The only way I have found to get it clear is to put the printer on its back with the paper tray facing straight up. Now push the tray in just a little bit if you can and try to shake it to get the paper to shift to the other end. After a minute or two put the printer back down and try to open the tray. If you can then just put the paper back where it goes in the tray. Be sure the pickup roller is clean, no paper dust and such. then try printing again. If you still can't get the tray out then you will have to dis-assembly the printer to get it clearer. Let me know if this gets you going.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 19, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
I get an error message that there is a paper jam in the front door, there is no jam. I open and close the front door and then it says the jame is in the fuser, ive taken that out and no jam hp 3550 laser...
Often when you get this error, there is a jam that is very difficult to see. You need to open the printer, remove the bottom two cartridges and the transfer belt. Then close the door part way and look straight down inside the printer. That part of the printer is called the registraion assembly and there is a paper sensor in there that often gets stuck with a small piece of paper after a paper jam is removed. You can carefully lift up on that assembly to unseat it and have a look underneath..
May 03, 2011 | HP Color Laserjet 3550 Printer
Paper Jame when i start printer after 10 to 12 houres and hang after three or four time restart printer then print the paper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 10, 2010 | HP LaserJet 1100 Printer
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper jam
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Nov 21, 2008 | HP LaserJet 4L Printer
HP 4 printer jam
I dont' think there is a site that exists. If this is a paper jam that occurs every few pages or so...you most likely will need to replace your pickup roller (located up under the machine after removing the cassette
Aug 26, 2008 | HP : HP4 Laserjet Printer
Error 41 on Brother MFC-3420C. I have tried unplugging and restarting. There aren't any paper jams or visible problems. There is dial tone to machine but fax will only ring when called, no start tone...
Hi,have the same problem since yesterday. Look on fixyourownprinter.com. """You can fix the ERROR 41. Go to www.bopparts.com and look up part# LK0935001. They sell it for $39.99 and it is very simple to install""".Good luck.
Apr 13, 2007 | Brother MFC 3420C All-In-One InkJet...
HP LaserJet 4 plus Printer Logo
331 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
