Question about Armani Exchange AX Chronograph Black Rubber Strap AX1050 Watch for Men
How Do You Replace The Battery - Armani Exchange AX Chronograph Black Rubber Strap AX1050 Watch for Men
Change battery
Usually, you remove the backplate and then the battery. Replace the battery without touching it by hand and replace the backplate.
Mar 08, 2015 | Watches
I need to replace the battery in Gucci 8505 Series 18535 what battery do I use
Any watch maker should be able to tell you what battery is needed and/or replace it for you.
Sep 19, 2014 | Watches
Invicta 6212 battery replace
open rear cover, replace battery.
Nov 26, 2013 | Invicta Watches
Replace battery
Best way here is take it to a jewler or even Walmart and let them replace the battery for you.
Nov 05, 2012 | Marc Ecko E15026G1 Watch for Men
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
I want to replace the battery in my chopard and i dont where
Open watch caseback. Undo the contact. Memorise numbers on battery and buy exactly the identical one. Replace the battery. Fit the contact back. Close the caseback. Reset the watch.
Mar 31, 2009 | Watches
Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Do not forget to rate, please.
Feb 03, 2009 | Bulova Watch
Need to replace battery
Take the watch to a jewlers, let him replace the battery they usually only charge for the new battery,
and they do not cost much.
Nov 12, 2008 | Pulsar PXF182X Wrist Watch
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Jun 01, 2008 | Casio DBC1501 Wrist Watch
Armani Exchange AX Chronograph Black Rubber Strap AX1050 Watch for Men Logo
Top Armani Exchange Watches Experts
Sock Puppet
Tom Chichester
Kelley Hopper
Are you an Armani Exchange Watch Expert? Answer questions, earn points and help others
