Question about Canon PowerShot A80 Digital Camera
It doesn't take pictures...
Everytime I try to take a picture, the icons on the screen are all there but the image I'm trying to capture doesn't show up. It's just a blank, black screen. If I try to take the picture, it just captures the black screen. I didn't drop it or anything, I just put it on one day and it started that. Please help. Thanks. 1.I am in possession of a canon powershot A80 CAMERA.2.On clicking blank image is getting displayed on the screen.however photos already on the memory card does get displayed on the screen.3.Suggest any service centre near Dehradun.
  • Canon Master
  • 4,738 Answers
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 15, 2007
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
My web cam is only video capture no picture capture.
Hello there
From the start menu, left click on control menu (these are the steps for XP yours might be a little different). Then on the dialog box that pops up, left click on the "Printers and other Hardware" option.
Another dialog box will pop up. Left click on the scanners and cameras option to bring another dialog box up. From there double click with the left mouse key on the icon for your camera. This will bring up the "Scanner and Camera Wizard."
Left click the next key to get to the image capture screen, position the camera and left click on the word "Take Picture" below the image. The image will show up on the scrolling menu next to the image capture part of the box. Select it (left click the small box next to the image to get a check mark in the box) or use the select all option to get all pictures, then left click the next key.
Select the picture destination from the drop down menus that appear and hit the next key to save. The next dialog box will ask what is to be done with the pictures. Select the option in front of the correct choice and hit the next key to bring up the final screen.
From here the picture location will be able to be opened. Left click on finish if finished or select the other appropriate choice. The images should be on the computer and ready to work with.
If there is no scanner and camera wizard available try the next option(if you are using iphoto plus).
Open iPhoto Plus and left click on the file option. From the drop down menu, scroll down to acquire and select source. Left click on select source.
From the dialog box that pops up, select your particular camera by left clicking on the down arrow key and scroll downward until your camera is found. Select the camera from the list by left clicking on it and then left click the ok button. (If your camera is already selected, this step may be unnecessary).
Now left click on the file button again select acquire and then left click on image. From the box that comes up make sure the radial button--the round area before the options--before the word "image" has a dark circle in it indicating it is selected. Then left click on the acquire button.
A dialog box will appear that is titled "acquire pictures from video". Position the camera for what picture is desired then left click on the capture button.
The picture will appear in a drop down menu on the other side of the video feed. Scroll down if need be and select the picture or left click the "select all" button if you would like all of them and then left click get pictures.
Now all the pictures should appear in iPhoto Plus. Save them to your computer with the save option or edit them at your leisure.
Oct 12, 2010 | Computers & Internet
How do I see my pictures in macro mode? If shows
click on the " flower" icon on the dial wheel to select the macro mode and then shoot normally. also, do remember to return to normal mode by pressing the flower icon again... or else you might end up getting blurry images.
Feb 18, 2009 | Canon PowerShot SX10 IS Digital Camera
Camera pictures uploading directly from W700i
when i capture picture the camra comes back on icon
Feb 20, 2008 | Sony Ericsson W700i Cellular Phone
Canon A520 Everything works, except the button you take pictures with. It wont work.
I need more information about what symptoms you are experiencing. I am going to guess that your shutter is stuck closed. This would cause a blank image to show on the view screen and your captured pictures. The regular icons and text would still display normally. Is this what you are seeing? If not please explain further what is happening and I will respond again with more information. David Millier Advance Camera Repair
Mar 12, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A80 Digital Camera Logo
238 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
