Question about Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac F6 Series hose replacement - Hoover F5906-900 Upright Steam Vacuum
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 37 Answers
SOURCE: hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
Posted on Sep 24, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
SOURCE: Hoover Steamvac hose won't spray water
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Posted on Jun 21, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Attach the hose to a "hoover f7425 900 steamvac v2 widepath
click here> http://hoover.com/file/670/ for the manual it will give you full instructions how to attach the hose
Sep 25, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
I need to replace my hose to my steamvac model F5842 can you help? Ordered a hose but I don't think it's the right one
Hi Chris,
Your Hoover SteamVac model F5842 needs the Hoover SteamVac replacement hose part number 40309007. You may find a link to the correct hose for your model below on our website:
Hoover SteamVac F5842 Replacement Hose Assembly
In terms of replacing the hose, this is an older style SteamVac, which attaches the hose to the front of the Dirty Water Solution Tank.
Here is are instructions on how to attach the hose to your machine:
http://www.fixya.com/support/t4699742-dont_manual_u_connect_hose
Hopefully this was helpful, and answered your question. Please don't hesitate to request a clarification, or add a comment if you have any further questions or concerns.
Thanks,
Chris Jones
Oct 07, 2011 | Vacuums
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
I need a replacement hose assembly for the hoover steamvac jr. any suggestions where i might find the part?
Only through a Hoover warranty/ service center if still available. If not save your hose ends and find a different hose with adaptable ends
Nov 25, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Attach upholstery hose
Jan 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac
What is you model number??? Is the hose ok and not broken where it goes into the motor? If it is then you will have to replace the hose asm.
Jul 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5906-900 Upright Steam Vacuum Logo
32 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
