47ln5750 turning on and off
How to upgrade firmware on LG 47LN5750
You can upgrade firmware from there official link
Dec 10, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Have a LG 47 inch tv. 47ln5750. When I power on the LG appears on screen then shuts off. took off the back cover and when I powered on I could see the LEDs flash. problem be led board? Or Led strips?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 27, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
I have a 55" lg flat screen tv. All a sudden i turned it on and the screen was black. You can see a little bit of it on the screen but. Very light. I tried messing with the setting didnt work.
Hi Rachel, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
LG No Picture Screen Flash 47LN5200 47LN5400 47LA6200 47LN5700 47LN5750...
May 01, 2016 | LG Televison & Video
I have a Lg LED tv model 47LN5750 that turns on but then stays on the LG "lifes good" screen and will not do anything more. what could be wrong?
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 13, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
I have a LG 47LN5750. No picture, sound yes, I see menu when using the flashlight test and have no back lights showing. please help with my next steps in fixing this issue. Just happened this morning.
What you are describing is common in these sets. The power unit tends to cause the LED backlights to fail. It is a 50 dollar parts cost but you have to upgrade the firmware to prevent it from happening again
Oct 09, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
LG 47LN5750 TV has no back light issue-
replace screen it's faulty period ensure it comes with T-con
Oct 03, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
LG TV 47LN5750 Backlight Out
Back - light problem? Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 14, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Using LG 47LN5750 functions on my TiVo remote control
Old codes do not work with new ones. If you wish to get new codes, check the sites linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://electronicshelponline.blogspot.com/
Jul 29, 2013 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
