Question about Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine
Sewing machine When sewing the top layer looks fine but underneath it is messy. Any suggestions or soluitions. Thanks
  • 208 Answers
The top tension pulls the top thread up. The bobbin tension pulls the bottom thread down. A balanced tension is an an even knot between the stitches.
If the thread is messy on the bottom, the top tension is non-existent or is too low. The top thread tension dial should be on 4 or 5. Pull the thread out and re-thread the machine with the presser foot up. If it is still messy, perhaps there is a burr on the bobbin case snagging the thread.
Posted on Jun 19, 2009
Can anyone help with problem sewing button holes in a waistcoat?
some sewing machine are not made to sew thick layers of fabric, the only suggestion I have is to try a new needle, make sure the top thread has not come off the thread take up lever, rethread the machine top and bobbin.
Apr 11, 2015 | Singer 6160 Sewing Machine
Singer 4411 sews fine forward and reverse in straight stitch, in zigzag top thread looks fine on top, but all loopy underneath and will only reverse stitch 1 or 2 zigs or zags
check that the bobbin underneath has the same thread as the upper bobbin and that you push all the way on the lever when sewing back and also, go full speed as this happened to me and that was my mistake. Hope this will help you :)
Aug 11, 2014 | Singer 4411 Sewing Machine
How hat do to adjust the tension on my Singer 3201 - the under thread is real loose
If the bottom stitches are messy it usually means the top thread isn't threaded correctly.
May 10, 2014 | Singer Sewing Machines
Husqvarna sapphire 870 quilt
Could be several things.
First, install a brand new needle, perhaps a top-stitch needle will work better because it has a groove in the shaft that protects the thread. Make sure the needle is the appropriate size for the thread you are using--a needle eye that is too small will cause the thread to hang or shred. When the needle penetrates the sandwich, the top thread forms a loop. If the eye is too small, the thread will not come back up through the sandwich, leaving a loop under the fabric.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point and retest your machine on a quilt sandwich made of the same fabric layers as your project.. Tension problems are more evident when sewing multiple layers of fabric, so tweak the tension until the top and bobbin threads meet in the middle of the sandwich.
I don't believe you will have to adjust the bobbin tension, but in case you do, be very careful. Mark the tension screw setting FIRST so you can reverse any changes you make. Bobbin adjustments are made in very SMALL increments. Because I tend to use a lighter weight thread for my quilting, I have a specific bobbin case that is adjusted for my quilt thread and I keep my other bobbin for regular sewing. Then I don't have to keep adjusting the bobbin tension when going from sewing a quilt to something else.
Some machines do better with certain brands of threads than others.
Adjusting Sewing Machine Tension to Prevent Problems
Mar 02, 2018 | Sewing Machines
CE-5000 thumping sound when I sew, messy stitching
any sound out of the ordinary could mean that a part is worn or fixing to break or something is loose
it's very possible that the machine needs to be serviced
Feb 08, 2012 | Brother CE5000 Computerized Sewing Machine
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
Sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
The thread is knoting underneath when sewing
It sounds like you maybe using the wrong needle size for the material you are sewing, or perhaps it is the thread. I've found that not all threads are created equal and it may be too fine/heavy for the needle gauge your using.
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
I hope this was helpful. Good luck and...
Happy sewing!
Jan 14, 2009 | Brother LS-1217 Mechanical Sewing Machine
Broken needle sewing through Corderoy
This machine should be able to sew 9 layers with no real problems but it may be necessary to use a bridge or hump jumper to go over the big hump. Set your stitch length to almost the maximum and sew slowly(one stitch at a time). If it buzzes just turn it off, shorten the stitch length and try again. The above applies if you are using regular thread. If you are using heavy thread, you will need to use a top stitching needle size 18.( It has a larger eye)and adjust your tension as high as it will go to remove the loops on the bottom.
sewman7
Dec 02, 2008 | Singer 7466 Mechanical Sewing Machine
Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Mar 25, 2008 | Bernina Activa 130
Singer Drop-In Bobbin 758B-28BH Mechanical Sewing Machine Logo
267 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
