Question about DFI LanParty KT400A Motherboard
Lanparty kt400a I have had my motherboard for 5 years now using Amd athlon AXDA2500KV4D, 1.5 gig of DDR PC3200 ram, 120gig WD Hard drive, NVG34AL DVI 128MB video card. I use it for gaming online and had no problems till now. What it does is it shuts off hard drive, cd/dvd drive but the fans and lights still remain. This problem happens when i am in bios or before windows xp is starting. I checked my hard drive on another computer and is good. I checked the cpu temp setting in bios before it shuts down and check was good. I also checked the psu on another computer and runs good. I thought that it could 1 of the memory sticks so i tried them on another computer and checks good. My setting are the same as it was for 5 years on the motherboard and bios and it down to 2 things the mother board or cpu but at this point i don't know of any way to check and see which one. Another example i should tell it that now when i try to turn on my computer the lights and fan run but nothing is loading or beeping just sits there.
  • jomorningstr Dec 26, 2007
    I have same problem, CPU heats to 93F and then shuts down. even external fan blowing wont help. sys temp is 72F it will boot to WinXP screen then as it gets warm. .shuts off.. have to let it cool off for 2 hrs with external Fan blowing on it (as well as NEW copper finned Heatsink / FAN (running at 3258 speed) its not enough,) WHO makes other slot A motherboards to check the CPU on??
  • WalkerBG Jan 07, 2008
    I used the cheap dfi ad77 to test my cpu and turned out good and I actually talk to dfi tech support and they said they would repair the board for $30 which is a good price. Socket A motherboards aren't being made anymore so if you would upgrade go for AM2 or AM2+.
  • 112 Answers
I have the same problem and i think its lanparty boards in general...
Posted on Jun 20, 2010
Yeep likely motherboard. test cpu in good system?
Posted on Nov 03, 2007
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
NVIDIA nForce4 Ultra
Front Side Bus
HyperTransport interface
Four 184-pin
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Award BIOS
CMOS Reloaded
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
Mother board manual for Acer T180 PC
WinFast K7NCR18 series is a compelling Desktop solution as a Socket A/AMD Athlon, Athlon XP, Athlon, and Duron-based ATX motherboard. WinFast K7NCR18 series, integrating NVIDIA chipset, supports the AMD Athlon processor whose performance is bound to exceed expectation of both consumer and corporate users alike. The WinFast K7NCR18 series also supports a 200/266/333 MHz system bus, PC1600/PC2100/PC2700/PC3200 DDR memories, and the latest graphics devices through the AGP 3.0 8X interface; and allows a direct connection to the graphics and memory for faster access to peripherals. An DVI/TV interface is multiplexed with the AGP bus and can be used to drive DVI compatible flat panel displays, projectors, and digital CRTs and TV monitors.
The Dolby Digital Interactive Content encoder is also integrated that can also process and output a Dolby Digital audio stream directly to a home theater system via a S/P DIF interface. WinFast K7NCR18 series offers innovative design, support for high-volume DDR memory, and configuration options that optimize performance and provide a robust, mainstream platform...
or visit at (’s-manual.html)
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 06, 2010 | Acer Aspire™ T180 PC Desktop
Chip up grade options!
is a socket 754 motherboard. It will support AMD Athlon processors up to Athlon64 3400+. It is a bit long in the tooth by today's standards, and only uses DDR memory, not DDR2. You may get more of a bang for your buck by buying a "barebones" system, which can consist of a motherboard with processor and memory, depending on how much you want in the barebones package.
Typically you use the case, power supply you already have with the new motherboard and processor and ram (memory).
At any rate, if you only want to upgrade your processor, keep in mind that your board only supports up to the Athlon64 3400+. It will support up to DDR 400 ram. You would probably benefit more by buying 2 sticks of 400 DDR ram at 2 gigs each, if you don't have much ram now. If your processor is close to the 3400+, then another processor in that board isn't going to change things much.
Good luck, and write back if you'd like more help.
Socket754 Supports AMD Athlon64 upto 3400+;
Nov 02, 2009 | Computers & Internet
Winfast n15235 motherboard manual
Mother Board ECS or MSI,Processor AMDuron 2.8 Dual Core w/1333 FSB,1 to 2Gig DDR2 PC667,160 to 250Gig Hard Drive Seagate Barracuda(7,200rpm) or Western Digital,CD/DVDwrite,512Video Card inno3D/Nvidia or ATI Radeon,LG or Samsung,Tower Casing w/ ATX Power Supply 500 to 600watts and LCD/Flat Screen 19inches wide screen or it up to you what you size LCD..Thanks..^_^
Jun 26, 2009 | Computers & Internet
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Upgrade Gateway AMD Athlon 64 Processor 3500+
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
I want to add more ram in my pc km400/km266
Oddly enough this board has the following specs: The board supports both Althon and Duron processors up to Athlon XP 2800+ (3000+ with a BIOS update). It can handle 3 GB of DDR333 RAM (or 2 GB of DDR400, but not all types are supported).
That's the older 184pin DDR ram in PC2700 or PC3200 guises. I can see no reason why it would only accept 2gb of the faster Ram.
Why not go over to  and run the online scan to get the true story on your board?
Jan 05, 2009 | AMD Via KT400 Athlon(XP)/Duron SktA DDR...
Amd sempron 2800+
i want AMD Sempron(tm) processor 2800+ free downloads driver
May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Asus a7n8x MB and ram
i just checked & yes you can from what i was reading
Mar 30, 2008 | ASUS EN8500GT HTD DDR II, PCI Express...
DFI LanParty KT400A Motherboard Logo
124 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
