SOURCE: Honda GCV160 Engine Won't Start
Hello
You should siphon out all the old gas you can. Replace with new gas. Check that the spark plug is good and the air filter is clean. Spray some carb cleaner in the carburetor.. Also, you should check the oil level and change the oil if it is black. If it tries to start after you spray the carb cleaner in but won't keep going then you know the carburetor needs a good cleaning
SOURCE: Reconditioned B&S pressure washer will not restart
Some suggestions:
Is the gas old? If in doubt replace it.
Try removing the air filter and spraying carburetor cleaner into the carb Then try starting it. If it runs for just a minute, then stops, the carburetor needs cleaning.
SOURCE: I have a 4,000 psi, 4.5 gpm 45G cat pump powered
I would just purchase a new unloader valve, they usually aren't worth rebuilding. I would like to have a picture of the set up that you have, if you can send me a picture of the unloader region of the pump I can get you are price on a new one. email is [email protected]
SOURCE: Just purchased a homelite 2700
Check for spark first If it has spark, remove the breather and put a few drops of gas in the carburetor.
ereplacemnet parts online
