Question about LG Flatron W2242P-SF 22" Monitor
Monitor displays verticle coloured lines when turned on
When turned on the monitor displays verticle coloured lines and doesnt display the LG logo or the menu. I have tried changing resolution and refresh rate but nothing i try seems to make a difference. Is there anything else i can try or will i have to send it off to LG for repair?
    New Friend:
  • 37 Answers
As i understood the explanation you have a problem with the Video card not the LG Monitor.
Posted on Jun 19, 2009
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
Acer netbook Aspire One doesnt support extarnal LG Monitor L192WS.How can I get the monitor to work properly?
First have you turned the port on for the monitor ? if not it usually is a function key like F2 ect. If this is done the right click on a free space on your desk top > then properties > settings tab ....and make sure you have two display checked in the drop box.
May 30, 2009 | LG Flatron L1750S 17" LCD Monitor
Moniter transitions to LG logo
Check the cable and make sure it is plugged in securely at both the monitor and PC. If the cable is connected properly, then the problem must be in the monitor itself. You could try setting the input mode manually on the monitor - the default should be auto - you could set it to VGA or DVI whichever your case is and see if it helps.
Jan 22, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
LG Flatron L1719S
i am having lg flatron l1719s green colour verticle line is appearing on monitor plz help me any one
karunya
Jan 13, 2009 | LG Computers & Internet
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
Verticle line in the middle of the monitor.
IT'S THE PROBLEM IN THE DISPLAY PANEL GET IT CHECK THROUGH A SERVICEMAN
Oct 01, 2008 | Toshiba Satellite P35-S611 Notebook
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
My LG CRT monitor does not display any thing when powered on
My LG CRT monitor does not display any thing when its powerd on .
May 21, 2008 | LG Studioworks 563N 15" CRT Monitor
LG Flatron W2242P-SF 22" Monitor Logo
161 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
