Question about LogiSys (KB606BK) Keyboard
LogiSys (KB209BK) Keyboard krys not working
Usb port switch makes some keys work, like the enter and backspace, but then the keys stop working again
Backspace key types, h key deletes nothing else works any ideas?
Try function and scroll lock at the same time the try to enter the password, if this does not reset your keyboard, remove the power and the battery for 3 minutes then turn it back on and try again.
Tony
Apr 27, 2014 | Acer Computers & Internet
Im using my mom Dell latitude D600 PC Laptop and It was working good then all of sudden S key wont Stop typing itself Till we press "r or T" it making it hard when it pops up out the blue. it...
It seems that your laptop keyboard is not working any more. you need to buy new keyboard for ur laptop or if you want to use usb keyboard then remove this keyboard's cable, connect your usb keyboard it will work.
Aug 21, 2011 | Dell Latitude D600 Notebook
When using my laptop it behave like any body has press backspace key I wont stop this problem,again I am pushing backspace key with my other hand it functioning properly,if I remove hand from backspace...
Hi dipannvora,
This could happen when they keyboard setting is malfunctioning or there is a possible virus which is the reason behind this misbehavior.
I would suggest you start the PC in safe mode and then check if it works fine , if it does , then the problem could be with a virus , else you need to get your laptop's keyboard serviced and the problem would be solved.
Aug 01, 2011 | Computers & Internet
Inspiron 1525 backspace and H keys not working.
you can always ket a keyboard off ebay. depending on the model its for between $12 and around $20
Apr 26, 2010 | Dell 0Y3740 Keyboard
Can't switch ports using PC keyboard
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Jun 17, 2009 | IOGear USB gcs1734 4-port KVM Switch
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
Cordless Desktop EX110 Keyboard stopped working
Have you replaced the batteries in the keyboard? It takes 2 AA batteries I believe.
If this helps, please rate this solution. Thank you.
Oct 17, 2008 | Logitech Cordless Desktop EX110
Backspace key
you might have sticky keys permanetly stuck on, ive had this problem, it worked after i held down shift and press the backspace key, then it worked nomally again. hope this helps.
Jul 15, 2008 | Acer NSK8458AN Keyboard
LogiSys (KB606BK) Keyboard Logo
Top LogiSys Computers & Internet Experts
Greg Ulan
Brett Duxbury
Brett Duxbury
Eric Andersen
Are you a LogiSys Computer and Internet Expert? Answer questions, earn points and help others
