Question about Eljer Home
Flushing more water
How do I make water conservation toilet flush more water
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Posted on Jan 18, 2009
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
  • 3 Answers
SOURCE: not enough water in the toilet bowl
WellI had the same problem with a client. never seen a stubborn problem like this. I was worried there was no vent on the toilet. My resolution was to get a new flapper from Moen. I replaced the existing flapper that had the yellow float. the float is designed to kepp the chain away from the flap. the existing flap had a vent hole in it. compare it to the new moen unit and you will see what im talking about. After the replacement things were better. Cheers
Posted on Jul 17, 2009
  • 62 Answers
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Posted on Sep 07, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
Kohler flush problems
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Aug 21, 2014 | Home
Toilet flushes but does not have the power to flush down waist
Aug 14, 2014 | Home
What is a flush cylinder
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
Aug 03, 2014 | Kohler - Toilet - One-piece - Santa Rosa -...
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Toilet does not flush clean. sometimes two or thtree flushes are needed to flush B.M> debris down. We have had the plumber out twice, once to install and the second time to raise the water level to...
Welcome to the world of 1.6 gallon flush toilets. You have already done everything that can be done to help the problem and no you are not the only people having this problem. This is just the beast!
They have had this problem with these 1.6 flush toilets from the get go and have come out with power flush toilets to fix this but hold on to your wallet. There are some toilets out there that work better without the power flush made buy American Standard and Kohler but they will run you more then the Jacuzzi.
Sorry I wish there was a better answer to this.
Mar 23, 2011 | Jacuzzi Home
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
Toto toilet does not flush properly - insufficient water to make it flush properly - need to pour water down toilet for it to flush. There is not any kind of blockage.
Check water level in tank for proper height it should be about 5/8 close to top of stand pipe in tank or it should have a mark on it wher it should be.
You can adjust the flush valve to increase water height.
May 13, 2010 | Home
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Home Logo
26 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
