Question about RCA RT2500 System
Only humming noise from speakers
Its a rca rt 2250 system
  • Derek Williamson May 11, 2010
    Does it hum even when its on the tuner/radio input?
    Problem Solver:
  • 7 Answers
The humming is probably caused by failing filter capacitors, these are usually quite large, also look for cold solder joints around parts the heat and cool continuously. Please post an update to further troubleshooting, if this doesn't solve the trouble.
Posted on Mar 18, 2010
Why does my HTS-20 powered subwoofer make a low hum when plugged in, even turned off and not connected to the receiver and a louder hum when the subwoofer power is turned on?
I suspect the amplifier is damaged. This is not an easy repair to do unless you are well versed in audio electronics. I would recommend a repair shop to look at the subwoofer amplifier.
Jun 03, 2015 | Infinity HTS-20 System
Have a humming noise in both of the speakers
Something's crossed, keep power lines and sound lines seporated double check wires in and out u could have bad sound wires and if so of home just buy new for a car get the RCA lines with a built in ground.
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
Apr 08, 2010 | Velodyne CT-100 Speaker
Popping and cracking noise from rt side speaker
You probably have a bad solder connection or an intermittent part failure in the right audio amplifier or its source circuitry. Put in a call for warranty service.
Dec 08, 2009 | RCA Televison & Video
Needs repair - loud humming noises when turned on who are service agents in Melbourne australia
had the same problem, so I installed a radio shack ground loop isolator and fixed the problem, it has 2 rca plug inputs and 2 rca outputs, goes in-between the sub and the input cables of your system to the sub...that's if your using the rca inputs..
Aug 04, 2009 | Sunfire True Sub MK II Subwoofer
Only humming sound from speakers, rca rt 2250
If its humming no matter what on all inputs, that means the internal electronics are worn out or damaged. This can be from a number of different things and isnt worth trying to have it fixed do the fact it would cost more than just buying a new one.
Jun 19, 2009 | RCA RT2280 System
Humming sound coming from transmission pan when key on
yes you need a filter on you amp to stop the noise through your speakers any car audio shop should be able to solve your problem
Jun 01, 2009 | 2008 Dodge Charger
Rca home theater system reciever makes noise when turn on
is it a humming noise, or a high pitch noise, and is coming from the speakers or the receiver?
Jul 21, 2008 | Audio Players & Recorders
Background "hum" in R speaker
Yea try plugging it into another wall socket, if it's still humming could be a damaged transformer. or bad capacitor.
Jun 05, 2008 | RCA RS2531 CD Shelf System
Problemas con RT 2250
http://www.rcaaudiovideo.com/Cultures/en-US/SearchResults.html?search=RT2380
Jan 11, 2006 | RCA RT2380 Home Theater System System
RCA RT2500 System Logo
211 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
