Question about Cuisinart GR-4 Griddler
Bad elements griddler - Cuisinart GR-4 Griddler
HOW TO USE CUSINEART GRIDDLER WITH 110v TO 220v
Get a step down transformer/converter. Grill consumes 1500watts of energy. Converts cost 200 dollars here at sim lim tower/square. Make sure get the correct watts, it is very important.
Apr 06, 2014 | Cuisinart Microwave Ovens
Remove plate that I accidentally placed on top that belongs on the bottom, how can I remove it?
The directions with my griddler says that the plates are interchangable, Check your model number and directions.
Feb 01, 2014 | Cuisinart GR-4 Griddler
Fat does not go into dripping catcher, it collects near lower heating element
check to make sure the factory feet are still on hte unit for level.
Apr 24, 2012 | Cuisinart GR-4N 5-in-1 Griddler GR4N
I have a griddler that has been used for greasy cooking--looks baked on. How do I clean the griddler? Water won't do it.
The best way to clean a griddle caked with grease is to turn it on and let it get hot. Then turn it off and while still hot, use a non abrasive cleanser (aka Comet, Bon Ami) with a nylon scrubber to cut through the grease. If the griddle does not have a non stick surface, you can get "screens" to work the grease free. This is what is used on professional grills (usually on a nightly basis). If all else fails, most oven cleaners will do a nice job.
Jun 16, 2011 | Vacuums
My Cuisinart Griddler Combo instructions tell you how to store the temperature control probe. I did not receive such with my griddler. Should there be one in the box?
Hello, W/D here.
Usually, the probe is built into the power cord, and is the long part that sticks out past the power connections. My best guess is that it is there.
Best regards, --W/D--
Feb 09, 2011 | Vacuums
Griddler
Try Sears Parts & Service. I don't know the cost.
Jan 29, 2010 | Jenn-Air Pro-Style JGCP636ADP Gas Cooktop
Top plate does not get hot, bottom plate is ok
The element could have a very fine crack in it, not readily visible. You must use a voltmeter to test if the element is getting power when the switch is turned on. If it is getting power, then the element is bad. If no power, then test the switch to see if it is sending power when turned on.
Jul 07, 2009 | Cuisinart GR-4 Griddler
The right knob had come off!
If your Griddler is still under warranty (3 yr warranty), Cuisinart will replace the entire unit for free. They do not replace knobs. (Cusinart knows if your warranty is valid by the serial number engraved in the bottom of your Griddler). You need to call Cuisart Customer Service at 1-800-726-0190 to get your Griddler replaced. You must pay a $10 shipping fee to get the new Griddler sent to your place, and you must return your broken one in the box they send you, and you pay for the return shipping.
Nov 09, 2008 | Cuisinart GR-4 Griddler
Stuck Grill plates
What happens is that the upper post (see the back of the plates; there's a quarter inch wide post) slides into a slot not designed for it (too small). To fix, find the post. Slide a table knife in between the plate and the griddler, and twist. This should un-jam the post and free the plate.
Feb 18, 2007 | Cuisinart GR-4 Griddler
Cuisinart GR-4 Griddler Logo
112 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
