Question about Sigma Bc 906 Computer
Reset total km
How do you reset total km and the total time?
Formular for working out km per litre
zero trip meter. fill vehicle to top fuel filler should cut out when full. Drive car then refuel to top. Note litres used and total km driven.
Formula Total Km divided by Total Litres = km/ litre value
Aug 29, 2017 | Cars & Trucks
Why can't I pass my emissions test?
If you had O2 sensor problems, the car would throw up an engine malfunction code.
You could try disconnecting the battery overnight to reset the ECU and emissions data. Run the car for a week of mixed driving and then retest. The test station should give you full info on what caused the fail. I would go somewhere else.
This is a emissions test cycle;
The cycle simulates an urban route of 12.07 km (7.5 mi) with frequent stops. The maximum speed is 91.2 km/h (56.7 mi/h) and the average speed is 31.5 km/h (19.6 mi/h).
The cycle has two phases: a "cold start" phase of 505 seconds over a projected distance of 5.78 km at 41.2 km/h average speed, and a "transient phase" of 864 seconds, for a total duration of 1369 seconds.
The dirty secrets of vehicle emissions testing
Oct 03, 2016 | Hyundai 2011 Genesis Coupe 3.8 R-Spec
How do I clear A-4200 on a Kyocera copier KM 2016
A C4200 IS A BAD LASER UNIT , EXPENSIVE REPAIR FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
I can't set total time and total odo on my Sigma BC 906. Because of place of dot. How to change the place of dot ?
The dot (".") on the "Total ODO" display is not decimal point, it is thousands (digit grouping) separator. If you want to set e.g. 330.75 km, then you enter "00.331". If you want to set 1145 km, you enter "01.145". The decimal point on this Sigma computer is denoted using decimal comma "," (as used in German and other lagnuages/countries) even if you set the language of the computer to English. You can see decimal comma e.g. in "TRIP DIST" display.
Jul 20, 2011 | Sigma Bc 906 Computer
How do you reset the service warning light on a Sportcity 250
When the vehicle is started and right after the ignition check, if there are less than 300 km (200 mi) left
to the next Service, the specific icon flashes for 5 seconds. Once the service mileage has been reached,
the icon remains steadily until the Service is reset.
The warning light can be zero set even if the mileage is lower, up to 300 km (200 mi), compared with
the Service mileage. During the 300 km (200 mi) before the service warning light comes on, the light
flashes 5 times each time the key is set to ''ON''.
The light should turn on first at 1000 km (625 mi). Successive times are strictly at 10000 km (6215 mi)
20000 km (12430 mi), etc
RESET
Hold the MODE button down.
Turn the key to ''ON'' and wait 10 seconds.
During this operation the service icon flashes.
Good luck,
Alex
PS-Don't forget to vote me, thanks!
May 07, 2010 | 2007 Aprilia Sportcity 250
Ms. Driva Reck drove from her home to the service station at 48 km/h. She returned home by bicycle at 16 km/h. The entire trip took 4 hours. How far was the service station from Ms. Reck's home?
Ms. Reck's trip on her bike took 3 times longer (48/16ths) so the service station was 48 km from her home. It took her one hour (1x48km)= 48km) to get there and 3 hours to get home (3x16=48km) for a total of 4 hours...
Nov 22, 2009 | The Learning Company Achieve! Math &...
HOW TO GET PAGE COUNTER IN KM-1510
Just hold down the stop/clear button for 3 seconds..
It will flash F24 then 3 increments then 3 more.. eg; F24>063>123
It means you have done 063123 copies/prints..
Sep 18, 2009 | Kyocera KM-1510 Copier
Trig and distance
Debs,
this is solved by starting with the SECOND leg of the flight considered as a triangle.
Find how far DUE east the plane travels (100 km x Cos10 = 83.9 km) using 10 degrees because that is how much is left of the 90 degree quadrent after subtracting the 80 degrres course direction.
Similarly find out how far DUE north the plane travels (100 km x Cos80 = 11 km).
Now get the total flight NORTH = 300 + 11 = 311
- and total EAST = 83.9
Finally, use Pythagoras theorem.to get the total DISTANCE:
square root of ( 311 squared + 83 squared ) = 321 km
Also the DIRECTION from its Tangent of 83 /311 = 14.9 degrees
Dec 19, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Sigma Bc 906 Computer Logo
Top Sigma Cycling Experts
Bill Boyd
Donald Ayers-Marsh
Are you a Sigma Cycling Expert? Answer questions, earn points and help others
