Question about Microsoft Presenter 3000 Mouse
Microsoft Presenter 3000 does not work
Dear Gurus,
I tried to syncronize them but nothing happens. I read that the USB Stick should have a green light on, is that right? Because mine is recognized when I plug it in but there is no Green Light
  • 3 more comments
  • Anonymous Jan 04, 2008
    presetern working
  • hehehe Feb 22, 2008
    the same problem
  • Anonymous Feb 28, 2008
    Yes, I have the same problem. Worked fine for a while but the the green light stopped and no more connection. Laser and display work fine.
  • Anonymous Mar 20, 2008
    just bought one too.. At first I was shocked as nothing was working, except for the laser. Microsoft has NO info! I did some research online, and found that I had to press some sort of button, which I could not lockate on the reciever.. Nor did I see any green light. Yet, I was aware of some sort of piece of plastic resembling a button at the back of the receiver.. I made the sigh of the cross and opened up teh receiver.. The first thing that fell was a tiny Surface-mount switch. I plugged the receiver back in the USB port (receiver being without casing) and temorarily mounted the switch in place, and pressed the switch.
    I finally saw the green light!! See, that was the problem. Working perfectly. Now I need to just solder teh switch back 2 place.
  • drummermalti Mar 20, 2008
My 3000 has a green light but it only flashes to indicate the sync period during which time you should press the button on the back of the presenter. The presenter works well and to date I have had no problems.
Posted on Mar 08, 2008
I had the same problem with the synchronization for this product. Even after finding the instructions for how to synch. the presenter would not advance slides. Finally, out of frustration, I did the synch process with the pointer right on top of the stick (touching the two together) and lo & behold the synch took. Apparently, the proximity of the two devices during synch is important.
Posted on Jul 14, 2009
Microsoft Wireless 3000 Mouse works sporadically (XP)
Turn off all other "wireless" devices (cell-phones, wireless telephones, iPhone) in your home, and see if the light on the receiver is "solid" on.
Sep 13, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Your problem lies only in mouse. All procedures followed are correct, but take a close look at the bottom of mice where the receiver is placed when not in use, look for a tiny thin button that protrudes from one of the sides, it has to be depressed while receiver is out, it might be stuck, try to press it down gently a couple of times, it must come out. If it doesn't work, take off battery, now press down mentioned button and release it immediately upon inserting back the battery. Hope will work ok. Good luck!! Chawah.
USB stick is lost.
was a new usb stiock found? same problem
Jul 01, 2009 | Microsoft Presenter 3000 Mouse
Won't advance slides
IF IT JUST DOESN'T WORK... (But the laser pointer is still working when in 'presentation' mode) You need to 'Sync' the presenter and the reciever... as follows: Turn the presenter on, and turn it over so you're looking at the back of it. See the button in the middle? Press that button, and the button on the USB reciever stick, simultaneously, while holding the two of them quite close together. Problem should be solved. If you turn it on and the display isn't working, or if the laser pointer doesn't work when in 'presentation' mode, you need to change the batteries. I thought I had a dud unit until I found out about the 'Sync' function!!! Definitely on the 'need to add to documentation' list!
Aug 21, 2007 | Microsoft Presenter 3000 Mouse
Wireless presenter dont work
Did you press the right button on the remote? To 'sync' the sender and reciever, and thus start it working, you've got to turn the handheld OVER and press the mysterious little button in the middle at the same time as the button on the USB stick. Also helps if you have them right next to each other when you do this. You should see a green light on the USB stick, and the laser pointer should work on the handpiece if the batteries are good. Mine was working fine for heaps of presentations then suddenly stopped one day and only the laser pointer would work. Batteries were fine, as is the common story. Then I found out that if you turn the presenter over and press the 'reset' button in the middle simultaneously with the USB reciever stick, the two 'sync' and it starts working again, hey presto. I've always found it a breeze to use once I figured this out. If that doesn't work take it back, you need a new one.
Jun 29, 2007 | Microsoft Presenter 3000 Mouse
Microsoft Presenter 3000 Mouse Logo
1,458 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
