Question about Agfa DC-1030S Digital Camera
Blank screen cant see photo's or image through viewfinder
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
No view from screen or viewfinder
Hi, have you tried another memory card in case the other one is faulty ,if the original card is ok then you will have to put into a fuji repairer to inspect. If you are still under guarantee the contact fujifilm.
Dec 17, 2015 | Fuji FinePix S5700 Digital Camera
No preview image
Hi there:
You can view pictures in the folder when connected the camera at pc monitor? but cannot take pictures or movies... the LCD stays blank?
If this answer is yes, could be a problem with the CCD image sensor, if no, your LCD display go to bad and will need replacement.
Check this interesting article about bad CCDs.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 07, 2012 | Nikon Cameras
Perfectly good photos but image in view finder will not focus Nikon D80 camera
Try adjusting the viewfinder diopter. There's a little dial just to the right of the viewfinder. Turn it while looking through the viewfinder. You want to be looking at an unfocused view or a blank wall. Turn the dial until the focus brackets are sharp. Make sure you do this with your shooting eye.
Nov 16, 2010 | Nikon D50 Digital Camera
No image is available to view on the lcd screen canon ixus85is
Click the "disp" button. The display of the camera has been turned off in the LCD screen but you can still use the viewfinder, this functionality is just for those who prefer to use the viewfinder instead of the LCD screen.
Jul 23, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Image in viewfinder slightly unfocused, photo clear.
Either your viewfinder needs to be cleaned or your camera needs to be cleaned. Most of the time it is the mirror in the camera that is causing this issue and cleaning it will make everything better.
May 30, 2010 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
No image on viewfinder Nikon D300
to see the scene on the LCD screen, use liveview mode.
Nov 28, 2008 | Nikon D300 Body Only Digital Camera
LCD screen
Unfortunately it is not possible to preview the picture on the camera's LCD screen before you take it.
The 300D is an SLR camera. What this means is that as light comes in through the lens it is deflected by a mirror (which sits in front of the sensor) up to the viewfinder. When you take a picture, the mirror flips up out of the way and a mechanical shutter opens, exposing the sensor to the incoming light. Because the mirror and shutter are in the way of the sensor, it is not possible to have a 'live preview'.
Compact cameras (which do allow you to preview the image on the LCD screen) work in a different way. They have a completely separate viewfinder, and they do not have a mechanical shutter - The signal from the sensor is simply switched electronically between the LCD screen and the memory.
On the plus side, although you might not be used to using a viewfinder, you will find the image you see is a lot bigger and a lot brighter that those you get on a compact camera.
Hope this helps,
Matt
Mar 04, 2008 | Canon Digital Rebel / EOS-300D Digital...
Agfa DC-1030S Digital Camera Logo
13 people viewed this question
Top Agfa Cameras Experts
CHIVOIU...
CHIVOIU...
Are you an Agfa Camera Expert? Answer questions, earn points and help others
