Question about Creda Washing Machines
Jackson j 1000 washing machine starts to fill then blows fuse
Starts to fill then blows fuse
    Genius:
  • Creda Master
  • 1,585 Answers
Sounds like heater elements gone
Posted on Feb 23, 2015
SOURCE: Washing Machine keeps filling with water
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Posted on Aug 13, 2008
MNTECH
  • 1543 Answers
SOURCE: washing machine continues to fill when starts
If it starts to agitate, that tell us that the water level switch has been satisfied. Unless the electrical contacts are fried inside the level switch (extremely rare) you need to replace the water inlet valve. It is the part the water supply hoses screw onto on back of the machine.
Posted on Oct 01, 2009
beltronic205
  • 1466 Answers
SOURCE: My washing machine keeps shutting down and blowing a fuse.
You must have a short circuit ,try disconnecting things start with the heater element, disconnect one wire see if it still blows...next try motor plug, until the fault clears at least this tells you what the problem part is.....
Posted on Apr 11, 2010
  • 2468 Answers
SOURCE: My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
Posted on May 14, 2010
  • 414 Answers
SOURCE: does anyone know how to check a fuse in my Bosch Maxx 1000 washing machine??
Try it in a different socket as it may not be the machine. The machine would have been factory fitted with a moulded plug, lift out the middle section and try a new fuse. If the unit failed after filling then possibly you have a short on the wash heater..you could verify this if you get power by setting a cold cycle or rinse and see if if completes it. Please also check that the consumer unit (main fuse box) has not been triggered.
Posted on Nov 26, 2011
Whirlpool washer blows fuse
the pump motor is starting to seize up. It is causing the motor to work harder which causes heating of electronics causing the fuse to blow
Feb 21, 2012 | Whirlpool LSQ8543J
Does anyone know how to check a fuse in my Bosch Maxx 1000 washing machine??
Nov 26, 2011 | Bosch Washing Machines
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine will not start. Timer dial clicks when it is pulled out, instead of starting.
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.Replace the lid switch with this part.
Jan 03, 2011 | Maytag Performa PAV2200
When the machine is started it fills with water,it then trys to turn and the fuse blows.
Check underneath if you can turn the motor easily by hand. It is probably the bearing/s that is/are ceasing up which causes the motor to strain and overheat and blow the fuse.
Sep 06, 2010 | Washing Machines
Start your wash machine
If your washer doesn't seem to work at all, check these: No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 01, 2010 | Maytag PAV2300 Top Load Washer
Jackson jpx-300. No water flow. No kinks in water
What you are hearing turning is the pump motor. The manual feature is for deliming the machine and and locks the unit in wash mode only.
It is likely your fill solenoid has malfunctioned if no water is entering the tank in a normal cycle.
Dec 21, 2009 | Jackson JPX-300L Dishwasher
Washer was in fill cycle and stopped
You've got a short circuit somewhere in that electrical circuit.
First, unplug the washing machine.
Replace the fuse. If it doesn't blow immediately, then there is likely a short in the washing machine, and from what you describe, it's in the motor.
If it blows, then there is something wrong in that circuit, and you can likely rule out the washing machine. Check all devices on that particular circuit, of which there can be a number of plugs.
Jan 23, 2009 | Maytag LAT3600A Top Load Washer
Teresa
Ron
Aug 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Jackson jp-24b
it needs a new drain relay box 120 volt the drain is stuck open the jp 24 were not very good machines the red lines are drain lines if you plug up the drian lines at fillup the machine will wash but now it will never drain a new drain box is not cheap i can sell you one at cost
Mar 12, 2008 | Jackson JP-24B Built-in Dishwasher
Washing Machines Logo
26 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
