Question about K2 Stormy 20" Girls' FrontSuspension Mountain Bike
Raising the handlebar - K2 Stormy 20" Girls' FrontSuspension Mountain Bike
How to raise handle bars on Kent model GS52683 womens 26"
Not able to answer without better description of model or a pic, but below is a link to the procedure for raising both types of handlebar/stem:
How to Adjust Handlebars
NOTE: if you have the "threadless" style and there are no spacers above the stem your only option is to purchase a "riser" attachment: stem riser Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Mar 04, 2018 | Cycling
Raising handlebars on schwinn ditch 2.0 dn
The above answer is incorrect. The Ditch has what is called a "threadless" fork/stem setup. One cannot raise the stem at all unless there are spacers above it. Raising the stem is also not the only option. A stem with a shorter "reach" may be sufficient. Google "threadless stem riser" to see options for raising the stem. Following is a video with the procedure.
Jun 09, 2016 | Schwinn Cycling
Raising handlebars
There is a single central connection to the handlebars This is called the "gooseneck". (Ther handlebars slide through the goosenect and then the gooseneck is tightened to hold the handlebars. The connector to tighten is in the front (so you do not get "injured" if you have a collison). Loosten the connector (it may be allen, or perhaps hex nut.). Raise or adjust the handlebars, then tighten. Make sure it is really tight (do not strip the threads). The handlebar has serrations to lock on to the gooseneck so the handlebar - gooseneck bolt will have to be loosened quite a bit to allow the serrations to "jump" to the next serration.
Sep 20, 2014 | Trek 7100
Lowering the handlebars on a mountain bike
This page may help. It is aimed at raising handlebars, but the same procedures are relevant. http://sheldonbrown.com/handsup.html
Sep 21, 2012 | Cycling
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
Trying to adjust handlebars and hex bolt will not release for raising the handlebars.Any suggestions??
It's not clear which of the two styles of stems you have but it's not all that complicated.
Get a grip (pun intended) on how it works:
If you Google "adjust threadless headset" or "adjust quill stem" you will find many video demonstrations on how to adjust it.
For example:
http://www.youtube.com/watch?v=ZsjZx9Kg7ng
http://www.ehow.com/video_4985708_install-quill-stem-bike.html
For solutions on raising the handlebars...
http://www.sheldonbrown.com/handsup.html
Jun 02, 2011 | Cycling
Can the handlebar height be adjusted on the mongoose deceptor bike?
The stem could be flipped over if the rise change would result in a hgiehr handlebar, but it would be minimal. That style of stem requires the steerer tube to be cut at the time of assembly and spacers are usually installed that would allow lowering the bars but not raising them since steerer tube length can't be increased.
Or, get a stem with a steeper rise.
Aug 22, 2010 | Cycling
Raising the handlebars
You will need a 6mm allen key to loosen ( turn anti clock wise) the handlebar stem bolt which when you sit on the bike and look down its just under yer nose :)
Please make sure when you raise the handlebars that as it lifts up there is a marking on the side of the handle bar "stem" with markings like this """"" if you see these you need to lower it down so you cannot see these.
Feb 28, 2010 | Pacific International Pacific Evolution...
I am considering converting the clip handlebar on my hyosung gt650r to the high handlebar of the hyosung gt652s,can you advise me how and what to replace or look out for.thanks
Simply type in 'Hyosung parts' in your preferred search engine and look for the replacement handlebar kit for an 'S'. Instead of the handlebars clipping on to the sleeve at the top of each fork like the 'R', the 'S' set is bolted on to the two other bolts you see on the inside top of your handlebars. It's as simple as buying the 'raising' kit, bolting it on; unbolting your existing handlebars and re bolting to the raised 'S' style kit. About a half hour job with a shifter!
Nov 09, 2009 | 2005 Hyosung GT 650 R
If your bike is older it might have a quill stem.To raise this you have to undo the allen key headed bolt situated where the bar & stem attach to the bike.It is often obscured by a plastic plug to prevent water rusting the bolt head.If this doesn't go high enough an adjustable quill stem must be fitted.
If you have the modern design of stem(A-head)you will have to replace the stem with an adjustable type which can be set upto 60 degrees.
Sep 29, 2009 | Cycling
K2 Stormy 20" Girls' FrontSuspension Mountain Bike Logo
52 people viewed this question
Top K2 Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a K2 Cycling Expert? Answer questions, earn points and help others
