Question about DeLonghi Heating & Cooling
How to take off side panels? - DeLonghi Heating & Cooling
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
2 Phillips screws recessed where hands go to lift unit. Then remove 4 plastic caps and 4 screws on each side. Sides should drop down 1/2 inch once screws are off that allows removal.
Posted on Jul 15, 2014
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Fuse diagram underhood
The 2003 Chevy Impala has four accessible fuse panels. There are two panels in the car's interior, on each side of the dash. There are also two underhood fuse panels accessible in the engine compartment. Removing the fuse panels is necessary to access and replace the Impala's fuses and relays. The panels are not attached by screws or bolts, and come off with ease.
Removing the Interior Fuse Panels
Open the driver or passenger side door and inspect the applicable edge of the dash. You'll see a panel marked "Fuses."
Grasp the fuse panel by its embedded handle. Pull the panel toward the rear of the Impala and outward to remove it from the side of the dashboard.
Push the panel toward the front of the Impala and inward to reattach it when you are finished.
Removing the Underhood Fuse Panels
Shut off the Impala's engine and open the hood. Approach the passenger side of the engine compartment.
Inspect the area beneath the passenger-side strut mount. Here you'll see two fuse panels.
Grasp the clips on both sides of the panel. Pull the clips outward and lift the panel to remove it, exposing the fuses. Repeat for the other underhood fuse panel.
Push the panel back over the fuse block until it snaps in place to reattach it. You can google it to find illustrations .
May 26, 2014 | 2003 Chevrolet Impala
Control panel does not always work
What control panel? The panel that dispenses water or the control panel inside the fresh food compartment? What is your model number?
Sea Breeze
Apr 02, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Removing front panel on DX4860 UR11P
First remove the side panel so that you can see the catches that hold the front panel to the metal frame. There might be a screw or two on the back of the computer that holds the side panel that you will have to remove. Most newer model computers will only allow the removal of one side panel. Once you remove the side panel look inside towards the front near where the side panel was and you will see plastic catches that hold the front panel to the metal frame. Push the Plastic catches so that they will release the front panel.
May 30, 2012 | Gateway Computers & Internet
Ac blowing heat on side and air on the other side.
Air Door Actuators Removal & Installation Console Mode To Remove:
  1. Remove the center console from the vehicle.
  2. Detach the air outlet duct from the center console.
  3. Disconnect the console mode actuator connector.
  4. Detach the console mode actuator from the center console.
To Install:
  1. Attach the console mode actuator to the center console. Torque the screws to 17 in-lb (1.9 Nm).
  2. Connect the console mode actuator connector.
  3. Attach the air outlet duct to the center console. Torque the screw to 17 in-lb (1.9 Nm).
  4. Install the center console into the vehicle.
Left Side Air Temperature To Remove:
  1. Remove the instrument panel carrier from the instrument panel.
  2. Disconnect the left side air temperature actuator connector. HVAC control module - left side gm-10-00-1844.gif
  3. Detach the left side air temperature actuator from the HVAC module.
To Install:
  1. Attach the left side air temperature actuator to the HVAC module. Torque the screw to 17 in-lb (1.9 Nm).
  2. Connect the left side air temperature actuator connector.
  3. Install the instrument panel carrier onto the instrument panel.
  4. Recalibrate the left side air temperature actuator.
Right Side Air Temperature To Remove:
  2. Disconnect the right side air temperature actuator connector.
  3. Detach the right side air temperature actuator from the HVAC module.
To Install:
  1. Attach the right side air temperature actuator to the HVAC module. Torque the screw to 17 in-lb (1.9 Nm).
  4. Recalibrate the right side air temperature actuator.
Mode To Remove:
  1. Remove the left floor duct from under the instrument panel (I/P).
  2. Disconnect the mode actuator connector. HVAC control module - left side gm-10-00-1844.gif
  3. Detach the mode actuator from the HVAC module.
To Install:
  1. If installing a new mode actuator, move the mode door to the middle position.
  2. Attach the mode actuator to the HVAC module. Torque the screw to 17 in-lb (1.9 Nm).
  3. Connect the mode actuator connector.
  4. Install the left floor duct under the instrument panel (I/P).
  5. Recalibrate the mode actuator.
Defrost Valve To Remove:
  2. Disconnect the defrost valve actuator connector. HVAC control module - left side gm-10-00-1844.gif
  3. Detach the defrost valve actuator from the HVAC module.
To Install:
  1. Attach the defrost valve actuator to the HVAC module. Torque the screw to 17 in-lb (1.9 Nm).
  2. Connect the defrost valve actuator connector.
Recirculation To Remove:
  1. Remove the HVAC module from the instrument panel.
  2. Detach the air inlet assembly from the HVAC module. Recirculation actuator removal and installation gm-10-00-1845.gif
  3. Disconnect the recirculation actuator connector.
  4. Detach the recirculation actuator from the HVAC module.
To Install:
  1. Attach the recirculation actuator to the HVAC module. Torque the screw to 17 in-lb (1.9 Nm).
  2. Attach the air inlet assembly to the HVAC module. Torque the screw to 17 in-lb (1.9 Nm).
  3. Connect the recirculation actuator connector.
  4. Install the HVAC module into the instrument panel.
  5. Recalibrate the recirculation actuator.
Aug 17, 2010 | 2004 GMC Envoy
Fuel pump reset switch
ford put there fuel pump reset switch in to places, one is in the trunk behind one of the side panels and the other is on the front passenger side by the feet right side panel remove that small plastic panel to your right and it will be their,,,,, it will be in one of the two places, trunk behind side panel or front passengers side by feet side panel to your right
Apr 06, 2010 | 1985 Ford Thunderbird
The driver's side control panel won't work. i.e;
There's a 50 amp fuse in box under hood. Could be the problem as far as I can tell there are no fuses in car. Check all connections. This just happened to my car. I tried using my passenger side panel an drivers side and drivers side window starting working. I put the drivers side panel on the passenger side and all other functions worked except my initial problem. I found my main auto switch on drivers side panel was bad which was causing all other functions not to work.
Jan 06, 2010 | 2004 Jeep Grand Cherokee
Where is the turn indicator flasher unit under the dash for 1994 pontiac sunbird
The turn signal flasher is located under dash panel, right side of steering column.
The fuse panel is located on the left side of the instrument panel. To gain access to the panel, pivot access door downward.
The hazard flasher is located under dash panel, left side of steering column.
Nov 04, 2009 | 1994 Pontiac Sunbird
Need help with dash removal.
  1. Remove the A-pillar and cowl side Trim Panels
  2. Remove the front floor console.
  3. Depower the supplemental restraint system (SRS).
  4. Remove the instrument panel side finish panels.
  5. Remove the 2 steering column opening cover screws.
  6. Remove the steering column opening cover.
  7. Remove the 3 lower steering column cover screws.
  8. Remove the lower steering column cover.
  9. Disconnect the steering column electrical connectors.
  10. Disconnect the RH side bulkhead electrical connector.
  11. Disconnect the RH side body harness electrical connector.
  12. Remove the 2 parking brake release handle screws.
  13. Disconnect the LH side instrument panel electrical connectors.
  14. CAUTION: To avoid damage to the clockspring, do not allow the steering column shaft to rotate while the intermediate shaft is disconnected.
  15. Remove the pinch bolt..
  16. Disconnect the adjustable pedal electrical connector.
  17. Disconnect the brake light switch electrical connector.
  18. Remove the 2 LH instrument panel center brace bolts..
  19. Remove the 2 LH instrument panel center brace nuts.
  20. Remove the LH instrument panel center brace.
  21. Disconnect the transmission range selector lever cable.
  22. Disconnect the RH side bulkhead electrical connector.
  23. Disconnect the LH side body harness electrical connector.
  24. Remove the 3 ground strap bolts.
  25. Disconnect the inertia switch electrical connector.
  26. Disconnect the RH side instrument panel electrical connectors.
  27. Remove the 2 RH instrument panel center brace bolts.
  28. Disconnect the vacuum connector.
  29. Remove the 2 RH instrument panel center brace nuts.
  30. Remove the RH instrument panel center brace.
  31. Remove the cowl panel grille
  32. Remove the instrument panel bolt located under the cowl panel grille
  33. Remove the instrument panel defroster grille.
  34. CAUTION: To avoid damage to the sunload sensor and electrical connector, remove the grille just enough to disconnect the connector.
  35. Disconnect the sunload sensor electrical connector.
  36. Remove the 2 instrument panel top cowl bolts.
  37. Disconnect the antenna lead-in cable.
  38. Disconnect the RCM electrical connector.
  39. Disconnect the center ground strap bolt.
  40. CAUTION:To avoid damage to the instrument panel, an assistant is required to support the panel before carrying out this step.
      • Before removing the instrument panel make sure all electrical connector wiring is free and not hindered.
  41. Remove the 4 instrument panel bolts.
  42. Remove the instrument panel.
  43. To install, reverse the removal procedure.
Feb 11, 2009 | 2005 Ford Explorer
Amana afd2535des side panel
the "side" panel of your refrig is actually part of the entire cabinet and is not replaceable.
Dec 16, 2008 | Amana AFD2535DES French Door Refrigerator
Heating & Cooling Logo
63 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
